87-92 305 Tbi roller cam specs
Hey everyone! I'm new here!
I am wondering what the oem specs are for 87-92 305 tbi roller cams. I would also like to know what their "powerband" is. I'm trying to see if it's close to the tbi cams that came in 87-96 tbi trucks, I know the trucks weren't roller but I have one that is and I need a roller cam that matches close to oem spec.
Re: 87-92 305 Tbi roller cam specs
Car: 97 Z71 Extended Cab
Engine: 5.7 Vortec
Axle/Gears: 3:42
Joker, that is what I initially did. Big mistake. The powerband for the vortec cam is 1500-4800 rpms. The powerband for tbi cam is 0-3000. Now I am stuck with a roller setup (that I dont want to change) but need a cam that is roller that would match oem tbi flat tappet cam specs, somewhat. So unless I want to put some deep gears in the rear, swap heads, intake, and get a tune, I need to swap the vortec out. However, I am not going back to flat tappet. Roller is better!
Anyone know the powerband for the 305 tbi cam? I found a sealed power cs-793 cam that looks like a stock replacement but cant find the rpm powerband. I called and they said its stock powerband of whatever it goes in... So at a loss.
Car: 1983 G20 Chevy
Transmission: 4L60
The Vortec cam in a 305 TBI runs very well. The 305 Vortec came with the same cam as the 350. Even the little 4.3 V8 in the Caprice came with the same cam. I have used the vortec cams in past builds and never had an issue getting it to run well. The torque curve actually comes on SOONER with the Vortec roller cam.
Engine: 5.7 Vortec
Axle/Gears: 3:42
Are you sure you have a Vortec cam?I've used them in a couple of L05's & L03's with good sucess.
Yes it's vortec out of a 97 Chevy. We took it out my buds dads truck when we were building it. Did y'all have swirl port heads?
I also have 700r4, stock converter, 3.42s and 32" tires. It's 4x4
Engine: 5.7 Vortec
Axle/Gears: 3:42
Yep.Swirl ports on the L05 & L03.The L05's ran ok,but,benefited a lot from tuning.The 2 L03's needed tuning & tweaking on a bit more to run well.Actually saw more improvement in torque & HP than expected.
My problem is when my truck shifts at 45 mph into od them tc locks up it's dropping down to 1250 rpms, then it shudders some and feels powerless until I get rpms back up over 1500 rpms. After 60 mph it feels fine though but I live nowhere near interstate so it never really sees above 65.
The powerband of vortec roller cam is 1500-4800. Stock tbi flat tappet was 0-3000.
Anyone know powerband of stock 305tbi cam? I'm trying to see what powerband of sealed power cs-793 is before I purchase. I don't want to mess up and choose wrong cam again.
Stock 350 tbi cams specs are: TBI cam : 165in/175exh .382 int lift/.402 exh lift Lobe Sep: ? (FROM TBICHIPS SITE)
Vortec Cam: 191int/196exh .414int lift/.428 exh lift Lobe Sep: 111
Engine: 5.7 Vortec
Axle/Gears: 3:42
What are you trying to accomplish?What problems are you having ?If all you changed is to swap from the L05 flat tappet to the Vortec roller on an L05,I would think you woulda saw improvement,but,no major problems.
I'm trying to get it to run and perform correctly.
Car: 1983 G20 Chevy
Transmission: 4L60
Those 350 TBI cam specs are way, way off, not even the 305 peanut cam is that small.
The 305 peanut cam was 178/194 @ .050, .350/.385, 109* LSA, 106* ICL.
The 305/350 vortec cam has faster ramps and not much more seat to seat duration, but has more area under the curve at 191/196 @ .050, .414/.428", 111* LSA, 106* ICL.
EDIT...What year is the truck and does it have a 700r4 or 4L60E? 1,250 seems AWFUL LOW (burn your transsion up low) to be in OD with the converter locked. On a 700r4 I would check to make sure that the TV cable is properly adjusted. Also keep in mind that going from 3.08s to 3.42s is going to need some recalibration to the governor or in the case of the 4L60E the shift tables. Either way if it has an electronic speedo in it, I would start with recalibrating the DRAC for the tire/gear change.
Engine: 5.7 Vortec
Axle/Gears: 3:42
I don't think the cam is your problem.TC studder is pretty bad w/ the 700R4's & even mine feels sluggish @ 45 in OD.I basically have the same truck setup as you 4L60E w/ 3:42 & 33" tires.I don't think your cams powerband is the problem tho.
If you look here http://www.jegs.com/i/Chevrolet-Perf...oductId=753961. It shows stock replacement for 350tbi with cam specs. They even had to boost compression to meet the 210 hp factory rating.
I have done diagnostics. This isn't a new thing it's a problem I've been chasing for a year. I just put new plugs and wires on the truck. I have used winaldl to datalog and all. I get no check engine lights or anything. Timing is set at TDC 0* like it should be.
Brian at tbi chips is the one who finally diagnosed my issue as the cam.
Engine: 5.7 Vortec
Axle/Gears: 3:42
I agree.If it's really that bad,I think you have some other problem.Just the swap to a roller shoulda netted you approx 10 HP.The added duration & lift,while not alot,should have added some as well.Befor I swapped cams again,I would go thru everything tuning wise before I swapped cams.Those cams work very well in a setup like yours.
I would not touch the cam until you do some diagnostic work and figure out what is wrong with your truck. Bucking and shuddering is very likely nothing to do with the cam. Check the timing (should be 4-6*BTDC with the Tan/Black wire disconnected and the Vortec cam) and also check the plug wires to be sure 5 and 7 are not swapped. You might have also retarded the cam 1 tooth on the chain inadevertently which would make it run horrible. The stock 305 builds peak torque at 2,800 IIRC and peak HP at 4,400 rpm....Not the idle-3,000 powerband you speak of.
Truck also has an instrument cluster from a 91 k5 blazer so I do have drac and electric speedo and I did the drac mod and have adjusted it to correct speed.
if you look here: http://67-72chevytrucks.com/vboard/s...=599897&page=6
I posted videos of what it is doing.
Car: 1983 G20 Chevy
Transmission: 4L60
Timing needs to be higher than 0*BTDC....4-6* works out well with some engines liking up to 8*. Watch your WINALDL datalog for knock counts. Also if you can screen shot the BLM table and post so I can see what is happening. You may be running lean and need some additional fuel pressure. Many stock TBI regulators came running as little as 9-10 psi of fuel pressure. Most stock engines need 12 PSI MINIMUM to keep from going lean above 3,500. With airflow mods they often need 13-15 psi.
Brian is a horrible fraud of a tuner, watch out for him. He will try to sell you stuff you don't need to cover for his poor tuning abilities.
That IS STOCK COMPRESSION RATIO for a light duty 350 TBI and it came with a 195-210 HP depending on application. There were about 4 different exhaust setups and several intake/air cleaner, and 50+ different stock chips for a 350 TBI.
Timing needs to be higher than 0*BTDC....4-6* works out well with some engines liking up to 8*. Watch your WINALDL.
What youre telling me about timing is totally different from truck forum.
here is my thread over there. http://67-72chevytrucks.com/vboard/s...d.php?t=624050
Engine: 5.7 Vortec
Axle/Gears: 3:42
Yes compression was good, I had a fuel issue where the dual tank setup was clogged but that has been fixed and now holding good fuel pressure and compression. No issues on that point.
It is so weird when I first crank up truck and drive it, before its fully warmed up, it shifts decent and the power doesn't feel robbed but once it warms up it does this. It used to shudder bad but now it doesnt even shake truck. I just feel its trying too hard.
Also, this truck will barely even bark the tires. On originally setup it would smoke the tires the hell off! and that was with a nasty oil burning high mileage stock engine!
Car: 1983 G20 Chevy
Transmission: 4L60
Also just noticed in this thread you are talking about it being a 305...Yet on the other site you said its a 350. Which engine is it, what injectors, what knock sensor and what chip BCC are you running???
Car: 1983 G20 Chevy
Transmission: 4L60
Stock injectors, stock knock sensor and stock chip.
Car: 1983 G20 Chevy
Transmission: 4L60
I had a LT4 corvette cam (203/210 @ .050, .476/.480", 115 LSA, 116* ICL) in my 8.75:1 350 in my G20 van. Stock 1992 G20 Chip with Tri-Ys it would BOIL the tires off. Stock torque converter and 3.08 gears.
Car: 1983 G20 Chevy
Transmission: 4L60
The stock 350 had a cam with specs as follows 194/203 @ .050, .383/.410, 112* LSA, 108 ICL
Yeah the original 350 tbi in the truck would do the same. Now after I out a new rebuilt engine in it wouldn't spin jack with 3.08s, now with 3.42s it will barely bark tires.
Engine: 5.7 Vortec
Axle/Gears: 3:42
Sounds like your timing way off.You shouldn't need premium gas.The L05/TBI is tuned to run on regular @ 9.4:1.If you have made tuning changes that require premium,IDK.If the ECM senses detonation,it will pull timing,killing power.It could even be false knocks being picked up from a noisy valvetrain,timing set,etc.What timing set & rockers did you use?Are you sure the cam is timed correctly.Not advanced or retarded?Somethin ain't rite & it ain't the cam.
Car: 1983 G20 Chevy
Transmission: 4L60
Car: 1983 G20 Chevy
Transmission: 4L60
100% sure of this and every autoparts house across the nation lists the stock replacement cam as this. It also lists a 204/214 grind as a replacement for more torque. The 204/214 cam, known as the MTC1 or the CS1014R runs GREAT in a stock TBI 350 with the stock chip.
Car: 1983 G20 Chevy
Transmission: 4L60
I am certain of one thing however. Under load your transmission should never allow your RPM to drop that low. My G20 would shift around 2,400 rpm at light part-throttle and drop back to about 1,600-1,800 rpm. It was NEVER under 1,600 rpm unless coasting. 700r4s do not build much line pressure at that RPM and it is EASY to smoke the clutches out of it at that RPM under load. It sounds like you have a governor or governor calibration problem or perhaps a TV spring that is too weak.
Engine: 5.7 Vortec
Axle/Gears: 3:42
Did you rebuild the engine or buy it.If "rebuilders pistons"were used w/o decking the block your pistons are sitting .020" farther down the hole than stock,killing compression & power.If you compounded that by using a thick headgasket,it'll be even worse.You would have virtually no detonation resistance due to lack of quench/squish.
Car: 1983 G20 Chevy
Transmission: 4L60
Read part 1, 2, and 3 of the TV 101 article by bowtie overdrives. Might just save you a transmission.
http://www.tvmadeez.com/article/index.php
Car: 1983 G20 Chevy
Transmission: 4L60
Yea I did and it is shifting WAY too early even for light part-throttle at that speed.
One other thing for diagnostic purposes remove and plug the EGR line to the EGR valve. When you added headers you may have altered how the EGR functions, allowing it to open more than it should, bogging the engine. I had to change from a positive to a negative backpressure EGR valve with headers or else I got code 32.
Car: 1983 G20 Chevy
Transmission: 4L60
Felpro rebuilder .038" compressed or the hard to find factory style .028" gray colored graphite ones
Your saying take off the vacuum line from the solenoid and plug on the egr side on the intake? I could try that. It does only shift and end up that low rpm until after it's warm. But that still doesn't explain low power feel where I can't spin a tire.
Felpro gasket kit, never let me down before. I can't remember what compression height pistons. That was almost 2 years ago. Even though truck doesn't even have 8k miles on it since rebuild.
Car: 1983 G20 Chevy
Transmission: 4L60
I did have to change egrs!! Gm one kept throwing code, I swapped to one that was opposite of it and no more code.
Not to mention most stock TBI engines enjoy 4-6* of advance over stock.
Engine: 5.7 Vortec
Axle/Gears: 3:42
Did you put in new pistons?If so,do you know part#,brand,or specs?Stock style headgaskets is not a good answer.LOL.There are several "stock" gaskets out there with different thickness.If you bought 1 of the budget rebuild kits,it most likely came with .041 gaskets & short pistons,which could have your pistons as much as .080" in the hole.You would virtually no detonation resistance which could have your ECM pulling timing.Your CR would prolly be almost 1 point lower & power would be way down.Then on the other end of that,if you threw some flat tops in there,had the heads milled etc,your CR would be too high,again timing would be pulled robbing you of power.
Car: 1983 G20 Chevy
Transmission: 4L60
Unfortunately Speedpro offers both a 1.56 and 1.54 compression height piston.
We have already established you have a .038-.041" compressed head gasket.
While both will reduce compression ratio and quench, I still do not feel this is your issue.
I am thinking its running lean and does not have enough timing.
What do your knock counts look like on WinALDL?
Where the pistons flat top with 4 eyebrows, dished with 4 eyebrows or dished with 2 long valleys on each side?
Knock counts were crazy when my return line was blocked but I fixed that. Would have to check again and datalog some.
Car: 1983 G20 Chevy
Transmission: 4L60
That makes little sense to be honest. The fuel pressure should be higher with a blocked return line. A rich mixture burns cooler and should have made for less knock. I have seen some of these fuel pumps get so weak they cannot even wet the return line, yet the truck will start, idle, drive, just runs with no power. I have also seen the regulator springs break, causing low fuel pressure.
