How to tell if a engine is a 2pc or 1pc seal?
Old Apr 16, 2014 | 09:47 AM
Necron's Avatar
Car: 2002 Camaro SS
Engine: Built LS
I'm going to go look at a 90 IROZ that was orginally a 305 TPI 5-spd but has been converted to a 355 carb motor. No idea where the 350 came from nor does the owner since the guy before him did all the work etc.
I found this: http://wiki.answers.com/Q/Is_there_a...it_up?#slide=2
So if it just has bolts going through the center of the valve covers it should be a 1 PC then?
Thanks for any help.
Old Apr 16, 2014 | 09:59 AM
aliceempire's Avatar
Transmission: T-5, TH350, T-5
Re: How to tell if a engine is a 2pc or 1pc seal?
SHOULD be a 1 pc. It's likely since the original flywheel was probably reused. But it is not guaranteed. Centerbolt valve covers can be bolted to ANY sbc.
Old Apr 16, 2014 | 10:04 AM
jokerZ71's Avatar
Car: 97 Z71 Extended Cab
Engine: 5.7 Vortec
Axle/Gears: 3:42
Best bet is to ck the block's casting #.
Old Apr 16, 2014 | 10:36 AM
Necron's Avatar
Car: 2002 Camaro SS
Engine: Built LS
Thanks for the quick response. I'll see if the owner can send me the casting #. Is there a certain number past that will be all 1pc rear main?
Old Apr 16, 2014 | 12:11 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
The casting numbers are not really sequential like I think you're thinking. Best thing to do is google the casting number, there are many sites out there that list the block information.
You might also be able to by pulling the valve covers off and looking down the pushrod holes for the dogbones and spider arms of a roller cam setup. If it has them, it's a 95% chance it's a 1pc RMS engine, unless the builder used a retrofit kit.
Old Apr 16, 2014 | 12:38 PM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
although not a gaurantee, most 1 piece rear main seals have the oil dipstick on the passenger side. and most 2 piece are on the drivers side.
Old Apr 16, 2014 | 12:50 PM
khulsebus's Avatar
Car: '89 Camaro
Transmission: 4L65/70E
Axle/Gears: 9 Inch, 3.70 gears
Checking the casting numbers would be the best bet. A date code would be a second option. A third is that all of the 1 piece rear main seal small blocks have an externally balanced flexplate, so if you popped off the inspection cover on the trans, you should be able to see the counter weight between the flexplate and the converter if you spin the crank slowly.
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
86White_T/A305
Aug 17, 2015 12:16 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Exxon Limited
Aug 9, 2015 08:13 PM
cRoe4
Aug 7, 2015 08:46 PM
