Interior Turn Signal Lights Stay On!!
Old Apr 19, 2014 | 01:20 AM
Arts89Iroc's Avatar
Car: Camaro
Engine: 5.7 TPI
Axle/Gears: Borg Warner/ 2.77
Just installed HID's and replaced the bumper turn signal lights with LED's but now my interior turn signal indicator lights remain lit when the light switch is on???
Old Apr 19, 2014 | 06:06 AM
CALIROCZ28's Avatar
Car: '98 Z28 LS1
Transmission: 4l60E
Axle/Gears: 373
Re: Interior Turn Signal Lights Stay On!!
Sounds like you have some crossed wires. Check the connections and grounds.
Old Apr 19, 2014 | 06:56 AM
jrhaus76's Avatar
Car: 1989 IROC-Z28
Engine: L98 - 350 TPI
Transmission: MD8 - 700R4
Axle/Gears: GH3/G80 - 2.77 POSI
That generally happens when you have a burned out bulb. Since you just did lighting work, as said above, check all your connections. Also, when you click the signal on, it stays lit inside, correct? Check the back. It should stay lit as well. Then check the front, are the signals on and staying lit? If so, all the bulbs are fine and it's a wiring issue....
Old Apr 19, 2014 | 07:30 AM
That generally happens when you put in LEDs (which draw ALOT less current than incandescent bulbs) but don't put in the right flasher for them.
You just need to get the right flasher.
Not a wiring issue. Don't get out your dykes.
Old Apr 19, 2014 | 10:33 AM
jrhaus76's Avatar
Car: 1989 IROC-Z28
That generally happens when you put in LEDs (which draw ALOT less current than incandescent bulbs) but don't put in the right flasher for them. You just need to get the right flasher. Not a wiring issue. Don't get out your dykes.
Good point. With minimal draw, the car probably "thinks" it's burned out.
Old Apr 20, 2014 | 12:06 AM
Arts89Iroc's Avatar
Car: Camaro
Engine: 5.7 TPI
I replaced the flasher with an electronic one, my bumper lights flash like they need to and the HID's turn on with no problem. But the interior lights still stay on. WTf!
Jae992
Aug 27, 2015 09:07 AM
Fronzizzle
Aug 17, 2015 02:52 PM
stalkier
Aug 13, 2015 12:59 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Fronzizzle
Aug 9, 2015 01:15 PM
