L98 113 heads, max lift.
Old Apr 29, 2014 | 12:48 PM
devilfish's Avatar
Car is 6spd l98 vette..
Im planing a mild build, ported lower intake, edelbrock runners, ported upper manifold. Headers etc..
The heads are stock L98 1989 vette 113 alu heads.
The cam I look at is the mild Comp Cam 08-501-8:
212/218 0,488 0,495 lift @ 050
Does this cam work with the stock springs, and general vavletrain clearance?
I can THINK of change the springs, if I dont need to hand in the heads for machining, if its a direct fit i mean.
I dont need a new never ending project...
Thanks for your time..
Old Apr 29, 2014 | 04:54 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: L98 113 heads, max lift.
Replace those old worn out springs with new ones .They are cheap enough
GM # 12495494 springs as used on the 113 heads when fitted to the crate ZZ4 engine
Drop in replacement
https://sdparts.com/index.php?q=deta...parts/12495494
http://www.summitracing.com/int/part...5494/overview/
Old Apr 29, 2014 | 10:30 PM
devilfish's Avatar
Thanks.
Is those spring a "drop-in" replacement?
Do I need new LT4 Valve Spring Cap Kit and retainers with those springs?
lt500r55
Sep 1, 2021 01:30 PM
509 camaro fan
Sep 6, 2015 10:43 AM
italiano67
Aug 31, 2015 06:04 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
anesthes
Aug 8, 2015 09:37 PM
