car won't run right. please help
I have a 89 Camaro rs with a 2.8l v6. I replaced the intake manifold gaskets and now the car starts and it shakes bad. If I floor the car it dies. If I rev it up it shakes worst. Thanks
Car: 91 Firebird/88 Firebird/91 Formula
Engine: V6 3.1/V8 5.0/V8 5.0
Transmission: 4L60/700R4/4L60
Axle/Gears: 3.23/2.73/2.73
Re: car won't run right. please help
Did you remove and replace any of the spark plug wires and connections? If so, double check you hooked them up in the appropriate firing order.
I replaced the plugs, wires, rotor, ignition coil about 6 months ago. The car ran fine before I changed gaskets. Except the intake gasket was leaking. I changed the sensor on the intake manifold, new thermostat, and injectors. I adjusted the rocker arms like it says to do in Manuel. Could it be that the timing is off? Also does anybody know what the compression should be per cylinder?
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
I would check the timing and make sure that the plug wires are installed in the correct spots/order. Also check for any other possible vacuum leaks.
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Car: 92 Camaro
Transmission: 5spd
Axle/Gears: Stock
try starting the engine and spraying water around the intake if it clears up the problem you have a intake gasket leak
