Is this injectors bad?
Old May 13, 2014 | 09:53 AM
claus290373's Avatar
Car: Trans Am gta 5.7 1989
Engine: 350 tpi
Transmission: th700r4
Axle/Gears: BG 9 bolt
Hey
Have a idle problem and have chance the IAC and TPS but it still idles bad.
Today i did ohm out the injectors and have 2 at 8-9 ohm and 4 at 12 ohm and 2 to at 16 ohm is this the problem or ?
I have no vaccum leak
Then the car is cold it idles okay but when its gets hot the idle goes up and Down
Thanks Claus
1989 5.7 gta
Old May 13, 2014 | 12:09 PM
OrangeBird's Avatar
Car: 1989 Firebird
Re: Is this injectors bad?
Originally Posted by claus290373
Hey
Thanks Claus
1989 5.7 gta
Hi Claus ,
Yes , you have bad injectors . When you mention a couple at 8 ohms and a couple at 16 ohms , that's all the proof that's needed . There is a TGO sponsor company called "South Bay Injectors" that you should check with for replacements . This company is highly regarded here at TGO and will do you justice on a set .
PS , that's quite a range of ohms readings , 50% is far outside of any acceptable tolerance for anything that should match as close as possible ..
Old May 13, 2014 | 12:40 PM
Engine: 350 tpi
Hello Have just ordred 8 inj from South Bay injectors
Originally Posted by init4fun
Hi Claus ,
Old May 27, 2014 | 01:48 PM
Engine: 350 tpi
Okay i have now 8 new inj. In my car and it drives super and have a Smoth idle.
Old May 27, 2014 | 07:39 PM
OrangeBird's Avatar
Car: 1989 Firebird
I'm very happy to hear of your success with it .
Old May 28, 2014 | 12:50 PM
Engine: 350 tpi
Hello is it normal that the inj.are a little noisy??
I couldent hear the old inj.
Old May 28, 2014 | 03:14 PM
OrangeBird's Avatar
Car: 1989 Firebird
Hi Claus ,
Yes , it's normal that some injectors are noisier than others . My new ones may a somewhat louder clicking than my old ones also , and have happily clicked for a couple of years now .
Old May 28, 2014 | 03:26 PM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Hi Claus ,
Mine are also noisy. But they work fantastic. Just close the hood and move along!
Enjoy!
mike_c
Aug 27, 2015 04:32 PM
Jae992
Aug 27, 2015 09:07 AM
86IROC112
Aug 21, 2015 07:20 PM
Bryan F
Aug 18, 2015 02:28 PM
