Fun day at the junkyard with $17
Car: 88 Firebird Formula
Engine: LO5 5.7 TBI/Ebl Flash
Axle/Gears: 2.73 stock rear end
Hey all got a great pull today at the junkyard!! I originally went to grab some bolts for my air dam thats on the way from Hawks. I grabbed my 10mm bolts off the donor car, and ive been wanting to buy a AC delete box for my upcoming header swap, but i wanted to check junkyards first and since i was there i said screw it i wonder if it has a Factory non ac box.......
The car ended up having it!!!! I ended up paying $15.99+tax, out the door $17.42! I got lucky and the heater box used 10mm bolts!!!! Getting ready to clean her down, and spray her with a layer of some rattle can paint. Quick question for anyone, does the AC box unbolt the same way as this box? Or will uninstalling it be different then what i did today pulling this one off? Any advice or information is greatly appreciated. Thanks!
Engine: 4++,350 & 305 CIs
Re: Fun day at the junkyard with $17
Did you get the wiring and HVAC faceplate?
Car: 1986 Trans Am
Your ac box should unbolt the same. If I recall last summer when I swapped mine over, one of the bolts came in from the outside instead of the inside or vise-versa. They are still all in the same location.
I'm in the same boat as you, got mine in the junk yard for $15 or $20. Don't know why people pay all that money for the fiberglass reproduction ones? (maybe no good salvage yards in their area)
So did a quick scuff with some 500 Grit, a layer of some paint and heres the finished product
Car: 89 formula 350
Engine: ls1 magnuson tvs2300 supercharger
Axle/Gears: 4.11 Dana 44!
you should go back and get the wiring and hvac plate. will be worth it to flip for some cash
Car: 1990 Camaro RS
Axle/Gears: 10 bolt, 3.73 Ratio, Torsen LSD
Nice find! That is about what a heater box should cost. For some reason there has been a trend among idiots thinking they are worth $125+. Usually they throw in a buzzword like 1LE.
with some wiggling of the box and maneuvering of the wiring harness i was able to get her out. Will post pics tomorrow
Car: 83Z28 HO
Transmission: G Force 5 speed
That's a great score!! If the faceplate and wiring is junk, you can always cut the resistor hole just a tad bigger and use the 3 element resistor from your AC box...that way you can retain all 3 blower speeds!
I'll admit, I paid a lot more for my AC delete box, but it's amazing how much room it frees up!! Changing plugs or header gaskets is a breeze now!
