CAM QUESTION
Old May 24, 2014 | 06:17 PM
SKYJR73's Avatar
Car: 92 RS
Engine: 5.7L
CAM QUESTION
I BOUGHT AN ENGINE, 5.7L TO PUT IN MY 92 RS. BLOCK NUMBER 14093638.
IT HAS A ROLLER CAM IN IT. CAN I PUT A FLAT TAPPET CAM IN FOR THE REBUILD. THE BLOCK NUMBER SAID IT WAS A 1987-1995 ROLLER CAM OR FLAT TAPPET. I WANT TO GO WITH FLAT TAPPET TO SAVE MONEY.
Old May 24, 2014 | 06:51 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: CAM QUESTION
I WANT TO SAVE MONEY.
You can but is false economy
Better Hp potential with a roller cam , easier to run new engine in (no risk of wiping out the new cam which gets rid of any " savings" you might make )
no need to buy new lifters if changing the cam in future
Old May 24, 2014 | 07:57 PM
DeltaElite121's Avatar
Car: 1988 Camaro
Engine: 377
Transmission: TH350; Circle D 4200 converter
Axle/Gears: Ford 9"
Re: CAM QUESTION
Unless the cam is just wild, rolling back to a flat tappet isn't doing you any huge favors. Every cam has its purpose, but you shouldn't be messing with a cam swap if you're trying to save money. You are playing with fire if you use an old worn set of hydraulic roller lifters with a new cam; particularly if it has aggressive lobe patterns.
beastin91rs
Oct 9, 2015 07:38 AM
SLNTSCPE
Aug 22, 2015 09:15 PM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
Fronzizzle
Aug 9, 2015 01:15 PM
