Lost oil out the back, any thoughts?
Old Jun 4, 2014 | 09:07 AM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
I finally got my engine fired up, ran for a few seconds and stalled, I was trying to dial in timing. I went to adjust the distributor and noticed something dripping. I looked under the car and pretty much whatever was in the pan came out the back of the engine, down the pan. It looks like rear main/oil pan area. I'm thinking something with the rear main seal failed and the pump just pushed it right out of there. Any other ideas? Regardless, I know that pan is coming back off, just more curious than anything else.
Old Jun 4, 2014 | 10:08 AM
red rock's Avatar
Car: 1987 iroc
Engine: 383 TPIS intake, Dyno Don headers
Transmission: 700R4 w/Pro-built Auto/transgo 2-3
Axle/Gears: 3.27/3.70 borg warner 9 bolt
Re: Lost oil out the back, any thoughts?
Is the oil leak as high up as the valve covers? I replaced the valve cover gaskets with silicone and the gasket rolled on the back side i didn't notice when installing, had to put my hand in back of the valve covers to feel the oil.
Old Jun 4, 2014 | 11:12 AM
drdave88's Avatar
Engine: 6.0L
No, the whole back side of the engine is dry around valve covers, intake, distributor, bellhousing, etc. just down the back of the pan. Its the oil pan/rear main area.
Old Jun 4, 2014 | 12:23 PM
RamIt's Avatar
Car: 1984 z28
Engine: Crate replacement L31R 350
Axle/Gears: 7.625" 28 spline 3.23
Sounds like someone forgot to put the oil galley plugs back in.
Old Jun 4, 2014 | 12:39 PM
red rock's Avatar
Car: 1987 iroc
YIKES!
Old Jun 4, 2014 | 12:41 PM
red rock's Avatar
Car: 1987 iroc
Old Jun 4, 2014 | 12:46 PM
khulsebus's Avatar
Car: '89 Camaro
Transmission: 4L65/70E
Axle/Gears: 9 Inch, 3.70 gears
Yeah, I was thinking oil galley plugs. There are a few plugs at the back of the block, behind the flexplate/flywheel that deliver oil to the lifters. Check out the pan seal in addition to the rear main seal.
Old Jun 4, 2014 | 03:21 PM
drdave88's Avatar
Engine: 6.0L
I know the oil galley plugs were there. Once I get it apart I'll check the rear main area.
Old Jun 4, 2014 | 07:55 PM
khulsebus's Avatar
Car: '89 Camaro
I thought the other guy was talking about the ones in the deck, towards the back of the block. A buddies truck has one that leaks there.
CarGuyDennis
137
Dec 6, 2016 11:02 PM
wbrooks63
Exterior Parts Wanted
Oct 4, 2015 08:40 PM
db057
Aug 22, 2015 08:17 PM
Navy8125
Aug 21, 2015 09:32 AM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
