ECU gone bad?
Old Jun 5, 2014 | 09:04 AM
strangeroc89's Avatar
Car: 89 camaro
Engine: 305 TBI
ECU gone bad?
well motor turns and turns yet fuel pump or nothing will come on. so at the main fuse by the battery i get no power with key off and with it on i get power on the red wire but nowhere else. This is a 305 tbi
Car: 89 camaro
Engine: 305 TBI
Re: ECU gone bad?
i guess ima head to a junk yard hopefully have replays by the time i come back
Old Jun 5, 2014 | 05:04 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: ECU gone bad?
https://www.thirdgen.org/forums/tech...formation.html
Originally Posted by strangeroc89
well motor turns
Nothing so far to do with the ECM
Old Jun 5, 2014 | 08:30 PM
Re: ECU gone bad?
How does this situation lead to ....
ECU gone bad?
Don't worry man; doesn't matter HOW BAD your ECU has gone, even if it's started hanging out with the seniors that stand around the dumpster out behind your school smoking ... strange things, who knows what; there's NO WAY IN THIS UNIVERSE that an ECU that's "gone bad" can produce that symptom.
Troubleshoot the lack of 12V deal FIRST. Reserve "bad ECU" for MUCH farther on down the road.
Study my signature, every single word, one at a time, ("simplest"..."all"... "probably"... etc.) for some REALLY GOOD mental discipline. Won't fix EVERYTHING that ever goes wrong, but will keep you out of the weeds most of the time.
Old Jul 14, 2014 | 10:20 PM
rknm88's Avatar
Re: ECU gone bad?
I got the same issue on a v6 3.1 1991 model... Lets share info... I have power in front of the firewall... Relays, Fuses, power all there... At the pump.. NO POWER AT ALL... AT THE REAR BULK HEAD... Keep me posted, I will do the same.. Car died in front yard and had been running perfectly... I am looking at ECU/ECM myself... There is only 2 or 3 possible things yet... I am going to HOT WIRE from BATTERY both a positive and negative lead... I will be using a FUSED LEAD... Good luck!
AmpleUnicorn88
Brakes
32
Nov 18, 2015 11:02 AM
Jerzyperson
Carburetors
Nov 13, 2015 01:07 AM
3rdgenkindagal
Aftermarket Vendor Review
25
Oct 21, 2015 09:32 AM
gta892000
Sep 16, 2015 12:40 AM
