help choosing heads
Car: 85 sport coupe
Engine: 355 sbc
Axle/Gears: soon 4th gen 3.23 w/ Posi
help choosing heads
I'm in the process of buying everythin to rebuild/build a 78 350 to swap for my 305. I plan on taking the eldelbrock performer intake and just putting it and the carb on the 350 from my 305.
My issue I need belp with is choosing heads for the motor. I kinda want to get some aluminum ones, but I don't know what dimensions or what not to get. Nor do I know if I should just buy some complete heads, or buy them bare. If I buy them bare, what do I need to make them complete. Also, by upgrading the heads, to I need to upgrade the cam? Or anything else.
I know it may seem like I don't know anything but I'm trying to learn. So pleas have some patience with me if I ask a lot of questions.
Thanks!
Thanks!
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Re: help choosing heads
Lost of questions and little information.
What are you goals for the motor?
What is your budget?
Can you assemble heads?
Why aluminum?
Why aluminum?
Car: 85 sport coupe
Engine: 355 sbc
Goals- keeping my car a daily driver but having the power to play around w/ at the track. 300+ hp maybe?
Budget is probably right at or around 1000
I've never assembled heads before
Just figured aluminum due to less weight, but since this isn't going to be straight drag, that much weight won't matter too much
Good aluminum heads are going to cost at least 1000 and you still need gaskets and bolts.
For 300hp I would get some vortec iron heads 1.94 valves. Have a shop clean them up if they are used, also install some new beehive springs. Then go with a mild cam and a vortec manifold. Get some self aligning rockers or have the heads modded for guide plates and go from there.
300hp easy
Depending on your cam (flat tappet or roller) you can make 300hp easy for about 1-1.3k
300hp easy
Car: 1988 IROC Camaro (RHD)
Engine: 350 ci L98 SBC
Transmission: T700
Axle/Gears: 9 bolt BW, Disk, Posi-traction
Check out the Pro Comp aluminium heads from Skip White. They seem the best bang for your buck.
I looked at those heads for a long time before I bought mine and I just could not convince my self that they were worth the gamble. Others enjoy them a lot.
Car: 85 sport coupe
Engine: 355 sbc
I didn't think the vortec heads would fit on the pre 86 blocks. I thought those were for the LS1s?
Should I get a new cam or just keep whats already there? for the rebuild kit, should I get the one that comes with new piston heads?
You thought wrong. LS1 engines use LS heads. Vortec heads will fit a standard small block chevy even pre 86. I have a set of modded vortec head on my 79 350 block.
I would get a new cam and I would match it to your combo. I would also save for a retro roller kit if you can.
Transmission: T700
I've been looking at Skip White Pro Comp aluminium heads for a while. Looks like the early ones had problems, but they have been sorted and are a good option now.
From memory the Pro Comp heads are copies of the Edelbrock heads.
The Procomp heads appear popular with racers.
Car: 85 sport coupe
Engine: 355 sbc
can someone post a link so I have an idea of what exactly I'm looking for. And how would I match the the cam?
Car: 85 sport coupe
Engine: 355 sbc
what do you guys think about these? the only concern I have is the valve cover stud
https://www.thirdgen.org/forums/engi...ker-heads.html
From Skip White PROCOMP 210 with cnc d comb.
Code:
Lift 300 400 500 600 650 700 Intake 161.6 206.5 245.2 270.0 270.0 270.0 Exhaust 131.0 148.2 152.8 152.8 152.8 152.8
Racers may like them because the run higher lifts, but even at high lifts dart and edelbrock similar cc heads can waste them.
Also remember these are NOT stock procomp numbers they are CNC modded procomps.
Most of us will not be running more than 500 lift. If we look at better heads with smaller intake runners we will see the same flow. The larger runners will make for a more peaky powerband. The smaller intake will give you much more linear power.
Here is a good example edelbrocks E street heads 185cc
Code:
Valve Lift .100" .200" .300" .400" .500" .600" Intake 63 125 182 225 248 249 Exhaust 51 99 131 153 163 168
For the thread starter if he is shooting for about 300 hp he wants small CC heads about 170-180 so he can make solid power across the entire band.
Do some research and reading on how heads and cams work and what the specs mean.
Car: 85 sport coupe
Engine: 355 sbc
ok, well what will I need to get for those heads to get running? will my eldelbrock performer intake fit those?
I really appreciate all of the help/info Midias
They use the standard SBC manifold pattern so probably the intake will fit but because edelbrock makes about 15 different performer manifolds I cannot be sure without a part number.
The valve cover bolt should not be an issue.
Car: 85 sport coupe
Engine: 355 sbc
ok, well I was planning on buying a rebuild kit from summit to rebuild the whole engine anyways. he also has a cam for sale and a double roller timing chain and was possibly gonna get those to go with them. What rocker arms should I get for these heads?
https://www.thirdgen.org/forums/engi...8-lifters.html
For rockers a set of comp rollers will be fine, I know a lot of guys running high energy diecast arms for a low cost solution.
210cc is WAY too big for a motor with a Performer intake.
I would avoid Skip White and other low-bid Chinese cheeeeeeepest of the cheeeeeeeeep (and not all that expensive either) junk.
Before choosing heads, it would be a good idea to figure out what your compression will be, with various combos. To get that, you need to know what pistons are in it; or at least, what the dish volume is, and how far "down in the hole" they are at TDC (aka "deck clearance"). What are those numbers?
Car: current project : 85 hard top TA
Engine: BUILDING : 409 SBC
Transmission: TRANZILLA
Axle/Gears: Dana 44: 3.92 spool
Personally, for the info i gathered from your post ... and the little power you are looking for, hyperuetectic pistons, scat crank and rods, get on ebay or call kmj performance they sell a set of Assault aluminium heads that will be more than adequate for your goals, hyd. roller cam and lifters, they make better power and are more reliable / forgiving . Keep the 1.6 rockers ( you can run a little milder cam and make the same power ) say around 232/238@ .050 & .462/ .488 lift & set your compression@ 10:1. this will yield 300-350 hp reliably for years
I would prefer an edlebrock performer RPM, but, the intake you have will support your pwr goals . just gasket match the runners and heads, use a 650 cfm carb. ( you can run a 750 but really ... you do not need to ). Put a decent distributor, coil, plugs & wires .
unfortunately, your not going to do all of the above for $1,000.00! You are going to need to have the tranny rebuilt as well . putting a fresh 300+ hp engine in front of a tired tranny and u joints is not something I would recommend
But, I would say to you ... buy what you can, as you can until you have all that you need ... then build it and put it in your car.
Car: 89 Firebird
Engine: 355 TBI
300hp easy
300hp easy
Yes, he can do that.. but the cost of buying used junk, paying to have them fixed and modified, will cost him more money & time! Iknow this from experience, you think you can save money but the reality is once you compare the two ways, you will see you didn't and more than likely ... you would have been better off buying a ready to run new set!
he doesn't have to get the set I recommend, but if he simply gets on line and really wants to find a good enough set of heads, he can, for less than most people think .
ebay, probably $600.00 for a complete set of 180-195 cc runner heads that will handle .550 lift hyd. roller! do what ya want, it's not a competition for me... just my opinion, from my experience .
good luck
good luck
I just jumped over to ebay, typed in : sbc aluminium heads & on the first page found at least 5 complete sets of heads for $513-650.00 that will make the power that you want, with no problem ( probably more. ) . you will find that, to make less than 350 hp with a 355 ci sbc..... you really have to try and put together a bad combination! the small block 350 is probably the easiest engine to make reliable power
Look, with a 4.030 ( .030 over stock. ), a 3.500 stroke ( could be 3.48 ), a 64 cc combustion chamber, a stock replacement bore/ compressed height head gasket, .010-.020 ( in the cylinder ), deck height & a 4cc valve relief flat top piston, will yield 10.2-10.3:1 compression, great performance and pump gas friendly . you don't need a huge runner head and / or cam package to make thbetter power than you are asking for .
just, keep driving what you have, buy a piece at a time and build it rite the first time, or you'll have nothing but problems!
Oh yeah, and when you order your rotating assembly, for the love of God, please .... get it with a 6" rod! it's just a better combo
Car: 67 ******mobile
Engine: 385 Solid roller
Axle/Gears: 4.11
[QUOTE=peterc005;5307825]
Hate to be a wet towel but racers are spending money on good heads, PC imo arent.
ProMaxx all those import pos.Unless Im mistaken the 210 pc needs a 1206gasket your performer wont be able to match that
Ask them how they are holding up after 15-20kmiles lol
Thinking most that buy them simply dont know any better
Please when itcomes to heads brand name is where its at you usually get what you pay for.
Know most are car poor (like myself) so the cheap price and big promises may get you thinking.. but saving up for good ones will save you headaches down the road
I agree. whole heartedly! I myself have tried to make cheap heads work & ended up with more money in them and got less head, than I would've if i waited, saved and bought what Iknew would work .
Any news on which way you decided to go? I am always interested in how different people build there engine and. what power it makes . I hope you succeed in your goals and if ya have questions, as you can tell by this thread .... there are many different back grounds and a wealth of knowledge here in this forum
92projectcamaro
Jan 18, 2016 08:00 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
