1991 Corvette L98 cam question
Old Jun 8, 2014 | 08:50 PM
PAFORM350's Avatar
Car: 1992 Formula 350
Engine: 5.7 L98
Im swapping a 44,000 mile L98 from a 1991 Corveete into my 1992 Formula 350. If you check my posts I've driven this car with a NOS 5151 kit to a 12.41 ET. Then a rod knock so I picked this engine up to swap it in. So my question is I'm thinking I might as well add a cam and some other parts to get som bang out of it. I really don't want to change the springs in the aluminum heads and wanted to know whether a Crane 2032 cam would be worthwhile. Most likely going to have a fully ported lower and lower manifold with SLP runners. If not this cam any suggestions? Also computer chip to help? Appreciate the help
Old Jun 8, 2014 | 11:15 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: 1991 Corvette L98 cam question
Your spring are old and of unknown quality; not withstanding the stock (.480" ? ) lift limitation
For $60 you can drop in new springs and retainers as used on the LT4 and ZZ4 crate engines good for .525 lift
( same alum heads used on ZZ4 engine ) giving you a better selection of cams
https://sdparts.com/index.php?q=deta...parts/12495494
Old Jun 8, 2014 | 11:26 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
For a 305
https://www.thirdgen.org/forums/tpi/...ne-2032-a.html
http://forums.corvetteforum.com/c4-t...ts-please.html
http://forums.corvetteforum.com/c4-t...t-for-l98.html
https://www.thirdgen.org/mods3
Old Jun 9, 2014 | 08:57 AM
cuisinartvette's Avatar
Car: 67 ******mobile
Engine: 385 Solid roller
Axle/Gears: 4.11
x2always put fresh springs in.
Old Jun 9, 2014 | 10:02 AM
PAFORM350's Avatar
Engine: 5.7 L98
Will the springs fit in the spring pockets without modification?
Old Jun 9, 2014 | 07:04 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
As I observed above
the ZZ4 crate engines use the same "113" alum head as fitted to the Vette L98 engines
Old Jun 9, 2014 | 08:50 PM
PAFORM350's Avatar
Engine: 5.7 L98
Thanks appreciate the help
Frozer!!!
Jan 19, 2024 04:55 PM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
redmaroz
Aug 16, 2015 11:40 PM
TreDeClaw
Aug 14, 2015 06:58 PM
