Valve Spring help please
Old Jun 12, 2014 | 06:47 PM
TennesseeIroc-Z's Avatar
Car: 1988 Iroc T-top
Engine: 350 w/typical bolt-ons
Transmission: 5 speed
Axle/Gears: 3.42 zexel, TEN chromoly 28 splines
I have an Edelbrock RPM cam, specs are 234/244 @ .050, .488/.510 lift. I currently am just using z28 springs on factory 882 heads.
I want to run 1.6 rockers with my new World Product S/R Torquer heads, but could use some educated advice regarding springs. Edelbrock recommends their Sure Seat valve springs:
1.7 installed height, .510+.050=.560 max lift, 120lbs inst. pressure, 330lbs @ 1.180 open pressure, 1.130 coil bind, 1.130 o.d. diameter.
If I run a 1.6 rocker, lift increases to .540, so add .050 = .590 max lift?
The spring specs on my World Heads are:
1.250": 110 lbs. @ 1.700", 300 lbs. @ 1.250", coil bind @ 1.160"
MAX LIFT @ .500 (specs from Bill Mitchell)
Which are inadequate I believe.
Would these springs work? There are some AFR 8020's for sale here on TGO:
1.437 OD 125# @1.800 pressure, 1.090 coil bind, 320 rate, 550 lift (specs from AFR)
If someone could point me to a proper valve spring for my application I'd appreciate it. Edelbrock doesn't have a spec for using a 1.6 rocker, so I'm trying to use the specs given for 1.5 while allowing for extra lift of the 1.6 rockers.
Thanks.
Old Jun 12, 2014 | 08:03 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: Valve Spring help please
Heads are at 1.700" install?
Afr's will work if pockets are cut large enough. I would consider +.050 locks so height is 1.750"
Old Jun 13, 2014 | 09:19 AM
According to the website spring pockets are cut for 1.5" springs. I dunno if those 8020 springs are still for sale, any ideas or part numbers I can look for that will work?
Old Jun 13, 2014 | 09:29 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Gm ls6 springs or beehives are popular upgrades
Manley 22410's are a great single spring that may drop right in. They may be slightly to much seat pressure at 1.70". They call for 1.75 so offset locks would be nice here. Then you gotta watch rocker arm to retainer clearance as offset locks move retainer up. May need lash caps which are no big deal but added expense
Old Jun 13, 2014 | 09:47 AM
Thanks Orr, I actually just was able to purchase the 8020's. Hopefully they will work.
Old Jun 13, 2014 | 09:58 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Yeah they should fit but make sure to measure install height on those heads first. If its 1.700", then you will want offset locks. If there are any factory shims on head remove them to try to get height closer to 1.78-1.80 that the afr's call for.
If not that seat pressure will be 157 lbs which is alot for flat tappet. Not terrible for aggressive rollers but i believe your cam is a flat tappet?
Old Jun 13, 2014 | 10:15 AM
Yes it's flat tappet, I thought the seat pressure for the 8020's were 125#?
Old Jun 13, 2014 | 10:17 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Yeah when installed at 1.800". If installed at 1.700" you gotta factor in 0.100" difference on the spring rate, which is 320 lbs inch. So .1 x 320 is another 32 lbs added to seat
Old Jun 13, 2014 | 10:20 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
With all that said I would not bother with that much lift on factory 882 heads.
Old Jun 13, 2014 | 10:21 AM
What happens if I install them at the springs recommended 1.8 instead of the cams 1.7?
Looks like I need to find a book.....
Old Jun 13, 2014 | 10:22 AM
Swapping out to World S/R Torquers...
Old Jun 13, 2014 | 10:25 AM
midias's Avatar
Are you porting them?
If not they lose flow after 500 lift
http://www.worldcastings.com/engineb...adflow2010.pdf
Old Jun 13, 2014 | 10:30 AM
Yes, I'm having some port work done. Mainly in un-shrouding valves, bowl blend and clean up the valve guide bosses. Gasket match. Nothing fancy. They do fall off over .500 lift in stock form, but I've read that they respond well to some mild porting.
http://www.caspeed.com/488hp383.html
Old Jun 13, 2014 | 11:35 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
See if you can get them at 1.75-1.8". Spring specs will then match afr's listing
pjsparts
Oct 29, 2025 06:39 PM
crzycamaro86
Sep 12, 2015 05:51 PM
ericjon262
Sep 11, 2015 06:07 PM
lakeffect2
Sep 7, 2015 03:52 PM
