Pulling my heads to bring to the shop... anything I should know?
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
Going to be pulling the heads off the motor I bought so I can take them to the machine shop for some exhaust manifold bolt nub extractions.
Since the motor has roller rockers and things I haven't dealt with before I was wondering if there's anything different I had to do or remember to do with reassembly later?
Or can I just pull the bolts, not touch the rockers, stab the pushrods into a box to keep them in order, and call it a day?
Just don't want to mess anything up!
Car: 1983 Z28
Engine: 385 Fastburn
Re: Pulling my heads to bring to the shop... anything I should know?
It's good practice to take them off if you're going to be moving it around and taking them to a shop, etc. You don't want to knock it on something/drop it/etc and cause damage that could have been avoided.
You at least have to loosen them to pull the pushrods out (unless you want them falling out all over the place when you pull the heads.)
Long story short-you have to mess with them anyways, might as well take them out, mark where they went, and reinstall.
just my
just my
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Take them off and when redoing install, have to set the preload one by one using the intake closing exhaust opening method. There are tons of online articles by major parts vendors discussing this.
Also good time for a valvejob, new seals and springs if old. Lol
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
Motor only has a couple hundred hours on it. Hopefully the valves look good!
I'll pull everything and make sure to mark which ones went where. Adjusting it all later will be a learning experience
Car: 89 Iroc-z
Transmission: TH400
Rockers dont matter where they go unless they are specific inlet and exhaust valve offset. Most standard sbc are just straight rocker and no offset needed so they are universal for any valve.
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
Doesn't everything wear together though? Like the roller tip on the valve stem and such? I know it isn't much but thought that stuff mattered.
ambainb
Apr 25, 2016 09:21 PM
Mickeyruder
Sep 2, 2015 02:45 PM
