can not read casting number
Car: 1985 pontiac firebird t-tops
Engine: 350 with 305 heads
Transmission: t-5
Axle/Gears: 4th gen rearend with 3.23 gears
ok so i have a engine sitting in my shed that i bought for $100. i cant read the code off the back of the block or off the front pad. this is the only info i can obtain from the numbers off the heads
they are 462624 heads
350
76-87
1.94/1.50 2.02/1.60
76cc Crack prone
has any one seen a block like this?
350
76-87
1.94/1.50 2.02/1.60
76cc Crack prone
Transmission: t-5
Re:can not read casting number
78 views and no replys thats not good Supreme Member
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Re: can not read casting number
The information you've provided does not help with an ID at all. Can't say much other than it's probably a 350 SBC. Treat it as a core.
Car: 86 Firebird
Engine: 305 SBC
Transmission: 700 R4 TCI
Since I doubt anyone would swap to those crappy heads it is probably a 350, you could pop a head off and measure the bore and stroke.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
See if there are any suffix numbers still stamped on the pad on the deck in front of the passenger head.
Transmission: t-5
i know it doesnt help thats why i asked if anyone has seen a casting number like this before its a first for me. i know its a 350 from the info i got from the heads casting numbers.
Transmission: t-5
it is a 350 i got that info from the casting numbers on the heads. it has been bored out i know that much. but i was just curious as to what it came out of.
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
If the pad on the passenger side front is blank then the motor has been decked... you'll have to measure how much to figure out heads/head gasket choice and such.
Transmission: t-5
behind the the flywheel is 207 and 509 and on both sides of the block is 207. other then that the pad on the front is bearly readable i think there is a 8 and t other then that nothing.
207 = early 80s 350 block
14010207
624 = 70s smogger garbage of the worst kind; makes an OK doorstop; not much else
Looks like you have a collection of parts, not any kind of original "engine"; so look at the rest of the parts, and they just are whatever they are
14010207
Transmission: t-5
that works not worried about the heads i have a set of 2.02 double hump heads. i just wanted to check out the block. i love doing research Last edited by blackd-out z28; Jun 24, 2014 at 04:22 PM.
