weird over heating issue
Old Jun 25, 2014 | 07:30 PM
blackd-out z28's Avatar
Car: 1985 pontiac firebird t-tops
Engine: 350 with 305 heads
Transmission: t-5
Axle/Gears: 4th gen rearend with 3.23 gears
i know this is not a firebird question but it is a question about a chevy v8. my grandfather has a lifted k10 with this motor http://www.jegs.com/i/Chevrolet-Perf...rentProductId= and it over heats. regardless if he drives it or not it will over heat in the driveway if left running long enough with or without the thermostat. doesnt burn oil and it doesnt use coolant. could the water pump be bad it has a brand new radiator. i had this problem once before in my eclipse and i changed the water pump and it never over heated again.
Old Jun 26, 2014 | 10:43 AM
OrangeBird's Avatar
Car: 1989 Firebird
Re: weird over heating issue
Yes , the water pump could have a bad impeller , or it could be the wrong pump alltogether . You DO know there are different rotation pumps for the different drive belts ( V belt vs Serpentine) , Yes ? If you have a V belt pump and a serpentine belt , your pump is spinning in the wrong direction and not pumping coolant through the system ....
Old Jun 26, 2014 | 11:47 AM
Ghettobird52's Avatar
Car: 88 Firebird Formula
Engine: LO5 5.7 TBI/Ebl Flash
Axle/Gears: 2.73 stock rear end
Is the fan turning on?
Old Jun 26, 2014 | 11:56 AM
RedLeader289's Avatar
Car: 1983 Z28
Engine: 385 Fastburn
^This^
I've seen it before
Old Jun 26, 2014 | 01:46 PM
Transmission: t-5
did not know that. so how do i know the difference? it only has the alt and ps pump so he doesnt need the serpentine belt.
Old Jun 26, 2014 | 01:53 PM
Car: 1983 Z28
Your local parts store SHOULD be able to tell you. I don't know the part number off the top of my head. I would call them first instead of possibly wasting a trip down there though.
Old Jun 26, 2014 | 02:02 PM
Transmission: t-5
luckily for me its right up the road the only down fall for me is the people who get jobs at the part stores by me is they are there just for the job and dont know poop about cars
Old Jun 26, 2014 | 02:25 PM
Car: 1983 Z28
Ah lol. Well, I tried looking up a part number and am not having any luck. If you told them it was for a (insert vehicle year and model that had a sbc and v belt set up) then you'd be good but I'm blanking on those at the moment. That's what I had to do.
Old Jun 26, 2014 | 04:35 PM
If i were you i'd verify that the fan is turning on (since you havent answered that) before you go changing the water pump.
Old Jun 26, 2014 | 09:13 PM
Transmission: t-5
oh my bad but its a clutch type fan with out the clutch
Old Jun 27, 2014 | 05:46 AM
Joe Tag's Avatar
So a mechanical fan with just a spacer? Do you have a fan shroud? Without one the fan will draw air from all around and not through the radiator as it's supposed to.
Old Jun 27, 2014 | 08:48 PM
Transmission: t-5
never had a issue with my 358 s10 thats why i figure water pump but good point. i will have to look into that.
Cornholio7979
Sep 20, 2018 02:31 AM
Cleotiz
Jan 6, 2018 08:56 PM
TheExaminer
Aug 26, 2015 04:59 PM
CORV3TT3
Aug 23, 2015 11:26 AM
IROCThe5.7L
Aug 10, 2015 11:24 AM
