416 or 187 heads on 350
Old Jun 30, 2014 | 10:08 AM
Sweet_Oddy's Avatar
Hi. Which of these heads would be better for low rpm torque? I want to get some more compression for my propane powered truck. It rarely sees over 3500 rpms. Its a 92 350 car engine I have a ramjet roller cam in it, shorty headers, holley tbi intake, 3" single exhaust. It hauls a camper around ect.
Old Jun 30, 2014 | 10:53 AM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Re: 416 or 187 heads on 350
For your application, definately the 187s.
Old Jun 30, 2014 | 11:15 AM
Sweet_Oddy's Avatar
Cool thanks. Should be alot easier to find some 187s.
Old Jun 30, 2014 | 11:46 AM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
They flow a little better on the exhaust side, should help get the heat from the propane out of the head. Also while the propane really does not need the added intake swirl, I really don't think it would hurt.
Old Jun 30, 2014 | 01:01 PM
Sweet_Oddy's Avatar
Maybie grind the ramp down a little then?
Old Jun 30, 2014 | 01:14 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
I would definately trim the end off, but don't just grind the ramp out, you will hit water. There is a ridge the cutter left from installing the valve seat that should be ground down. Also it wouldn't hurt to cut the seat for a 1.94" valve and use a good multi angle seat cut. A 5 angle radiused seat should help contact and help get the heat out of the valve. Do some research in the propane head setup as building and setting up a head for gaseous fuels is a bit different than gasoline.
Old Jun 30, 2014 | 04:28 PM
Sweet_Oddy's Avatar
[QUOTE=Fast355;5785524]I would definately trim the end off
Meaning grind the top down like .100"? or is there a different spot?
Old Jul 25, 2015 | 09:45 PM
Sweet_Oddy's Avatar
Ok now what about these 059 heads? Would they be a better choice than the 187s? This thing is off idle up mostly. low to midrange. I am thinking of a jy turbo job maybie off a 5.9 cumins or 6.5 chevy.
Old Jul 26, 2015 | 08:18 AM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
059s flow GREAT and have a nice chamber. Should make great off-idle and midrange power on a 350.
Old Jul 26, 2015 | 08:59 AM
Sweet_Oddy's Avatar
Oh. I forgot to mention its a manual. So it really is "off-idle". 5th gear 1500 rpms frequenly.
Old Jul 26, 2015 | 12:21 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
You might look into the GM Gaseous fuel vortec engine camshaft part number. Not sure which cam it is, but GM claims GREAT low-midrange torque out of it.
http://gmpowertrain.com/2013_pdf/FHR...ust_122112.pdf
Old Sep 8, 2015 | 10:22 AM
Sweet_Oddy's Avatar
Ok, the i got a set of 187 heads off a 1990 truck. Looks like they were rebuilt at some point they have the guide liners in them and look pretty good considering. Looking through the intake port it looks like i should grind the corner off the swirl ramp. Bad idea? Any insight on the intake ports being siamesed like that?
Attached Thumbnails 416 or 187 heads on 350-20150907_181718.jpg   416 or 187 heads on 350-20150907_181611.jpg   416 or 187 heads on 350-20150907_181828.jpg
xkingcodex
Feb 12, 2020 07:43 PM
Jake_92RS
Jan 28, 2020 10:37 PM
theshackle
Mar 5, 2017 06:37 PM
beastin91rs
Oct 9, 2015 07:38 AM
NinjaNife
Aug 23, 2015 11:49 AM
