Throttle body gasket question.
Old Jul 12, 2014 | 08:10 PM
jermdm's Avatar
Car: 1989 Iroc-z
Transmission: Auto 700R4
Axle/Gears: 9 bolt - 2.77
I'm going to be changing the intake an plenum gaskets on my 89 iroc with a 350 TPI. Since I will have everything apart, I figured I'd change the TB gasket as well. When looking at gaskets, I've always seen that there is 2 TB gaskets included in a set or if bought individually, there is 2 to choose from. From what I've read, 89 was a 1 only year for the TB design. Does anyone know which one I should use in the pics attached? Or do I match the gasket to the design of the gasket surface on the TB? Thanks.
Attached Thumbnails Throttle body gasket question.-tb1.jpg   Throttle body gasket question.-tb2.jpg
Old Jul 13, 2014 | 06:30 AM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Re: Throttle body gasket question.
Maybe this might help. See post #11:
https://www.thirdgen.org/forums/tpi/...dy-gasket.html
Most upper manifold gasket sets (plenum to runner) come with both style TB gaskets. Just match up the old gasket to either one of the new ones.
1992 Trans Am
May 10, 2023 07:19 PM
mdtoren
Aug 23, 2015 12:52 PM
lakeffect2
Aug 23, 2015 08:44 AM
86White_T/A305
Aug 17, 2015 12:16 AM
mdtoren
Aug 16, 2015 05:45 PM
