Throttle Body Gasket
Old Apr 25, 2001 | 08:53 AM
snoozeyaloose85's Avatar
I just bought new upper&lower intake plenum gaskets. The kit came with 2 different gaskets for the throttle body which one do I use? 85 305 tpi TA
Old Apr 25, 2001 | 09:02 AM
Also the bottum of the throttle where the iac screws into and I think some water port. There is a gasket on there with a bunch of little bolts. What's that gasket called and how come I didn't get it in the kit.
Old Apr 25, 2001 | 09:07 AM
custman87T/A's Avatar
the felpro kit I just used had two TB gaskets also but if you look at them only one will line up with the throttle body on your car...use that one. The other gasket you are refering to is not in that kit since there really isn't a need to remove the coolant passage on the bottom of the throttle body. If you need the gasket the autoparts store can look it up for you but you can also reuse it if its not too bad.
Old Apr 25, 2001 | 09:27 AM
Do you mean line up with the bolt hole's Cause i think both mine did just the middle was different.
Old Apr 25, 2001 | 10:38 AM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
1 gasket has 2 TB holes cut out in it. The other doesnt. Go with the one that doesnt have the 2 perfect holes.
Old Apr 25, 2001 | 12:15 PM
Why that one will it make a difference will it run different. There must be a reaon for difference. Thanks for the reply's
Old Apr 25, 2001 | 01:50 PM
remove your TB and put the gaskets against it you will see that one will line up perfectly and one will not. Take a guess at which one you use
Old Apr 26, 2001 | 05:46 PM
Still wanna Know why there 2 different ones I used the one with the 2 holes cut out is that the wrong one
Old Apr 26, 2001 | 09:16 PM
86TpiTransAm's Avatar
Car: 1986 Trans Am, 1991 Firebird
Engine: 355 TPI, 3.1L V6
Transmission: 700R4 in both
I don't know about the throttle body gaskets problem but the other gasket you are talking about comes in a throttle body gasket kit from GM!
GM P/N 17113115
Old Apr 26, 2001 | 09:20 PM
[This message has been edited by 86TpiTransAm (edited April 26, 2001).]
Old Apr 27, 2001 | 12:06 AM
72LT1VETTE's Avatar
Car: 1972 LT1 Corvette
Engine: 350 HO
Transmission: M22 Heavy Duty 4 Spd
Axle/Gears: 336
The TB gasket with the triangle hole lower center is for 85-89 MAF units. This allows idle air to pass through lower plenum to the small idle air tube and on into engine (small tube on driver side runner). The gasket without the triangle hole is used for Speed density TB's on early or late model plenums. Idle air passes thru machined slots with this TB into top of plenum behind throttle plates.
Old Apr 27, 2001 | 10:09 AM
Excellent I guess I used the right one. I have the 85 with maf so i used the one with the triangular hole. Thanks alot
1992 Trans Am
May 10, 2023 07:19 PM
db057
Sep 4, 2015 07:57 AM
mdtoren
Aug 23, 2015 12:52 PM
lakeffect2
Aug 23, 2015 08:44 AM
mdtoren
Aug 16, 2015 05:45 PM
