Odd battery question
Old Jul 14, 2014 | 09:20 AM
92White25th's Avatar
First off, if this is not the correct section I do apologize but I felt it was the best one based off of my question. I went to remove my negative battery terminal and felt a slight charge in my hand from holding the wrench, is that normal, I never experienced that before with batteries? Also to play it safe since I am working on some wiring in my engine bay I felt safer unhooking the positive side as well. My other concern is that now that I disconnected both batteries, when I seem to touch metal, I apparently still get shocked. However, when I was working under the hood yesterday, with the battery still connected to measure voltage, I never got shocked. Is this normal or is something wrong with me, haha? Now I do have several pieces of metal surgically implanted, would that have any effect?
Old Jul 14, 2014 | 10:01 AM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
Re: Odd battery question
What you're feeling is most likely static electrical discharge and nothing to do with the batteries. You can hold the contacts on a car battery and feel nothing. There isn't enough voltage to push the electricity through your body. You get a static discharge just by rubbing some material and touching grounded metal. I get it all the time getting out of my car with cloth seats and touch the door metal.
Old Jul 14, 2014 | 10:07 AM
That would be some crazy static electrical charge. It was just weird because I was just standing their next to the car and felt it has soon as I touch the socket to the battery terminal. So I just put on some gloves and a long sleeve to keep me safe.
Old Jul 14, 2014 | 10:50 AM
ok now I am concerned. just about everything I touch that is metal I get shocked. even my gear shift inside the car. never happened before until I went to disconnect my battery. I have disconnected batteries before with not ever having any issues. I really don't know what to do know. Now I feel that I wont be able to drive my car unless I am wearing gloves. What do I do? Everything was fine yesterday, today I started fixing a couple wires that were suggested in another post that could be causing another problem I having.
Old Jul 14, 2014 | 11:10 AM
Yep, scratch last post figured it out. Something very dumb on my part
Old Jul 14, 2014 | 11:44 AM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Care to share how dumb? May prevent someone else from doing it too.
Old Jul 14, 2014 | 12:10 PM
rusty vango's Avatar
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
haha, good one .the metal that you and I have been put back together with are made non magnetic .non ferrous metals. I THINK its titanium.fun at airports!!
Old Jul 14, 2014 | 12:21 PM
I would not say overly dumb, but still dumb none the less. I do not have a lot of light in my garage. So I rested one of those lamps, you know the kind that have a metal hook on it, on the small metal bar by where the hood attached to the truck release. So after I was done touch everything metal on the inside of my car I went back inside to write the concerned post. I then went back outside and just simply took the light off the hood and carefully sat in the care a lightly touched the gear shift, all went well. Touched the chasis around my radio, all went well. Then walked around to the engine and began touching everything in y engine that was shocking me. So I strongly feel that removing that hanging lamp with the metal hook from the care stopped everything. Not sure how but once I moved it no more shocks. So that's my excuse and I am sticking to it.
Old Jul 14, 2014 | 01:13 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
I'd check the wiring on that lamp!
Old Jul 14, 2014 | 02:45 PM
Sure as heck never going to use it next time I work on my car. Or I will have my wife hold it. Hahaha
Old Jul 14, 2014 | 02:54 PM
mmadden55's Avatar
Car: 86 Firebird
Engine: 305 SBC
Transmission: 700 R4 TCI
She will love you for that. not.
Old Jul 14, 2014 | 03:00 PM
Scorpner's Avatar
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
The ground on the lamp or electrical wiring in the garage may not be grounded. I would get it checked out and fixed.
Old Jul 14, 2014 | 06:28 PM
Lurbie's Avatar
Car: 89 Camaro
Engine: Dart SHP 400-Holley Terminator EFI
Transmission: Tremec T56 Magnum F
Axle/Gears: Strange S60 3.55:1
Definitely be careful, either fix the lamp or cut the cord and throw it away! I've been electricuted so bad once I couldn't move. Stepped into a puddle that an extension cord was laying in, both my legs froze, I could feel the shock all the way up to my thighs, I leaned forward and literally fell out of the puddle. Something like that really wakes you up to be more alert and safe about what you're doing.
Old Jul 14, 2014 | 06:50 PM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Axle/Gears: 10-Bolt/2.73
I was once shocked removing my battery, now I remove the negative terminal first. Oops.
Bought myself the Summit LED work-light. No cords, metal cages, fragile glass bulbs or heat. LED's are my friend.
Frozer!!!
Jan 19, 2024 04:55 PM
Street Lethal
Apr 30, 2019 12:14 PM
TA8487
Interior Parts Wanted
Aug 23, 2015 01:34 PM
redmaroz
Aug 16, 2015 11:40 PM
