Timing Chain Gasket Leak?
Old Aug 14, 2014 | 01:53 PM
TPIguy87's Avatar
Car: 1987 Trans-Am GTA
Engine: 357
Transmission: TCI Streetfighter
Axle/Gears: Borg Warner 9 bolt
Hey guys, I have quite the leak coming from what seems like the timing chain seal or the oil pan gasket. I used degreaser to clean off all the oil under the engine. (I've been finding the oil to be running back and drippin off the starter, off the oil pan, and eventually making it's way to the trans pan. Both pans are not stock, I have a bigger oil pan and a TCI tranny in there. Anyways, after I cleaned up the oil mess I went and tightened the oil pan bolts which were not by any means tight, the two larger bolts in the front were also loose. After I was done with that I noticed oil seemed like it was running out from the front of pan where it meets timing chain cover. SO. which is it?
Old Aug 14, 2014 | 05:38 PM
Keoman's Avatar
Car: 1989 IROC & ROLL-Z
Engine: L98 Vortec FIRST TPI
Transmission: T56, Mech Speedo
Axle/Gears: G92 J65 3.27
Re: Timing Chain Gasket Leak?
If this is true, its most likely your pan gasket. The oil pan gasket seats against the bottom of the timing over.
The timing cover gasket comes in a C shape (i assume you know this already)
If it was the timing cover gasket, I think you would see oil leaking up higher under the water pump ish
Bare SBC for refrence
Old Aug 14, 2014 | 06:55 PM
TPIguy87's Avatar
Engine: 357
Alright thanks for your help, cleaned it up again and am going to let it sit over night to see exactly where it is coming from
Old Aug 15, 2014 | 06:22 AM
Smog pump been hacked off of it?
Make sure there is a bolt in THIS hole.
If there's not one, you can look in it and see the fuel pump drive rod. Put a SHORT bolt in it with a drop of sealer on the threads.
Old Aug 15, 2014 | 07:55 AM
Joe Tag's Avatar
You can see that bolt in the pic he posted, but making sure it's sealed is a good idea. I say start it up and crawl under there (easier said than done I know) If it's as bad as you say it will be apparent where it is before long.
Old Aug 16, 2014 | 01:38 AM
TPIguy87's Avatar
Engine: 357
@sofakingdom, the PO hacked the smog pump out, but was smart enough to put a bolt in that hole, that was my first place I looked and actually hoped there wasn't a bolt in there, cease, an easy fix. But no, still have been leaking a little after I tightened everything up but nothing out of control. Thanks for your help guys
Old Aug 16, 2014 | 07:25 AM
Dakota W.'s Avatar
Car: 1991 Christine Z28
Engine: RV Cam and Intake 350 SBC
Transmission: 5speed
Axle/Gears: 3.08 ls Posi
Ran into this problem with mine after new engine swap. Some oil pans require different size gaskets up there. There are thin and thick gaskets, and I'd wager you need a thick one.
Old Aug 16, 2014 | 09:24 AM
Scorpner's Avatar
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
They typically leak up in the corners by where all of the goop is hanging out, especially with the original stock pans (where they round out). It could possibly be leaking up there and coming out at the bottom. My Milodon pan has extra meat and reinforcement in that area but I'm not sure what the pan you're using has. I still added extra sealer to that area as a couple of engine building books recommended it.
You seem to know what you're doing but I'm going to say it anyways, don't over tighten the bolts. lol
Good info on the thicker gasket, I didn't know that.
Old Aug 16, 2014 | 10:27 AM
TPIguy87's Avatar
Engine: 357
Thanks for the info, yes I didn't tighten anything tighter than they should be, it'd make it leaking worse, though the two larger bolts in front had about 2-3 turns in each of them, which id say is much too loose...
Old Aug 16, 2014 | 10:43 AM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
been a few times i wish i had one of these leak detector kits.
1992 Trans Am
May 10, 2023 07:19 PM
drewdock87
South Central
Aug 18, 2015 09:02 PM
MY87LT
Aug 17, 2015 08:43 AM
86White_T/A305
Aug 17, 2015 12:16 AM
