A few more quick questions.
Old Aug 20, 2014 | 09:58 PM
penguinpanda0's Avatar
Car: 1987 IROC-Z Camaro
Engine: 305 LB9
87 iroc 305 tpi, the sensor is right next to the oil filter. Its oil temp right? I know oil pressure is near the distributor for my year.
Anyways, that sensor has chewed wires to it and I'm wondering if that would cause any other unforseen issues. Struggling with code 33.
Old Aug 20, 2014 | 10:21 PM
aliceempire's Avatar
Transmission: T-5, TH350, T-5
Re: A few more quick questions.
No such thing as an oil temp sensor on a factory thirdgen. The sensor directly above the oil filter by only an inch or so is for the oil pressure gauge. I'm not sure if 87 was at the distributor or filter but if I remember right TPI had it down by the filter and carb'd by the distributor. Don't quote me on that. As far as your code 33 http://www.chevythunder.com/myweb/maf_code_33.htm
Old Aug 20, 2014 | 11:06 PM
Engine: 305 LB9
Okay, well my car is factory and I have sensors in both locations. I took out the factory oil pressure sender to replace it with my autometer one, and it was up top near the distributor. I can take some pictures if you want.
I know is 87 is a weird year, anyone wanna shine some light on this?
Old Aug 20, 2014 | 11:28 PM
Engine: 305 LB9
Old Aug 21, 2014 | 01:16 AM
91 camaro racer's Avatar
Car: 91camaro rs,2014 silverado 5.3L
Engine: 5.7Lcarb,5.3L
Transmission: 700-r4, 6L80
Axle/Gears: strange 3.73's
the one by the filter should be for your dash gauge
Old Aug 21, 2014 | 05:16 PM
Engine: 305 LB9
What would the distributor one be for in stock applications if not the gauge? Why would the bottom one need two wires if its just running a gauge?
Old Aug 21, 2014 | 06:22 PM
ok, maybe the one by the distributer is for the gauge and the one by the filter is for your fuel pump?
mine is a 91 and it uses a combo sensor by the oil filter, gauge and fuel pump. but the fuel pump portion is just back-up incase the relay goes out it will send power to the fuel pump if you have oil pressure.
Old Aug 22, 2014 | 03:41 AM
rusty vango's Avatar
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
Originally Posted by penguinpanda0
that one down by the filter is the oil pressure switch for the fuel pump. according to my FSM for 87.
Old Aug 22, 2014 | 06:14 AM
The one you have by the distributor is not for a factory gauge. It's aftermarket.
Old Aug 29, 2014 | 06:46 PM
Engine: 305 LB9
Old Aug 29, 2014 | 06:50 PM
Engine: 305 LB9
So what problems, if any, will I face by having the wires chewed to that switch?
F-body-fan
Jan 12, 2023 01:49 PM
meeklay812
Oct 1, 2015 03:46 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
Royal_Z
Sep 30, 2015 08:45 PM
raymondandretti
Sep 27, 2015 06:43 PM
