Sending Unit Removal...
Old 08-22-2014, 09:27 AM
propaintball96's Avatar
HOW THE F*&#@ DO I GET THIS OUT?!?!?!?
Old 08-22-2014, 09:44 AM
Joe Tag's Avatar
Re: Sending Unit Removal...
The two tabs sticking up are part of a lock ring that holds it in. Take a hammer and a flat screwdriver and peck them around counterclockwise. You will have to alternate from one tab to the other because it will drive the ring to one side when you work it around and bind it.
Old 08-22-2014, 10:04 AM
That's what I thought but it wont budge...any hints/tricks?
Old 08-22-2014, 10:38 AM
Joe Tag's Avatar
Looks like it's cut out from the tank? Use some penetrating oil on it. Clamp the sheet metal in a vise so you have it stabilized and can put some torque to it. If that fails drill out a few of the spots holding the outer ring to the "tank" and pry that ring away from the lock ring. You don't want to beat up the sender.
Old 08-23-2014, 05:13 AM
aramirez121's Avatar
Car: 1991 camaro rs v6
Engine: v6 3.1
Transmission: auto
i had it were it was binding did u press the tabs down also you can pop one side out and then pull it off from there if that fails get some tin snips and cut it
Old 08-23-2014, 12:19 PM
rusty vango's Avatar
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
no.spray it with PB blaster. tap it lightly. alternate like he said DONT booger up the lock ring.
tattmann
09-27-2015 05:20 PM
82xCAMAROxZ28
09-27-2015 12:31 AM
wstephan96
09-25-2015 04:28 PM
6998poncho
09-25-2015 02:56 PM
lanceflame44
09-25-2015 12:28 PM
Quick Reply: Sending Unit Removal...
