Camaro 85 iroc gear no engaging
Hi I have a camaro 85 iroc fuel injection and I have a problem when driving the car I have to raise the rpm about 3500 rpms for the trans to jump on second gear and same with the second and 3rd it has brand new transmission some one can help me I'm thinking about the shifter cable but is the oxigen sensor can cause the car acting like that ? Or the catalytic converter can cause it if is no good please help thank you
Car: 88GTA
Engine: 5.7TPI
Re: Camaro 85 iroc gear no engaging
see this post, sounds like cable WAY off!
https://www.thirdgen.org/forums/tech...ble+adjustment
I order a new cable when installing do I have to ajust it or just put it as it is and should be tight enough with out doing any adjustments ? I check mine and I see that is a lil loose but I don't know how slack is suppose to have ??
Car: 88GTA
Engine: 5.7TPI
Is your Camaro TPI or TBI? Did you review the link?
Here is another link. Its not hard to set.
http://api.viglink.com/api/click?for...le%2Findex.php
Car: 88GTA
Engine: 5.7TPI
The cable must have been messed with when the tranny was worked on/taken out, or something along those lines.
I had a friend with a 85 Monte Carlo SS and his auto trans went out. It would not upshift AT ALL from first gear. He had it rebuilt,set the cable, and motored on.
Ok so pretty sure the cable is bad but today I'm gonna change it and hope fix the problem thank you very much if something comes around I will reply back thank you again for ur time
Car: 89 IrocZ
Engine: L98-ish
I didn't look at the links posted, but assume they are "How to adjust the TVC"..links.
Linson
Aug 21, 2015 02:12 PM
mustangman65_79
Aug 11, 2015 03:17 PM
