Help... vacuum leak? replacement vacuum lines
Old Sep 2, 2014 | 11:10 PM
jstratouly's Avatar
Car: 88 Iroc Z28
So Ive had my 88 iroc for a few months now and have slowly been fixing it. most recently i replaced the left(drivers side) valve cover gasket as well as the pcv valve. It has a 305 in it with the TPI. I know the vacuum lines need to be replaced, due to old age and damage. Any suggestions on wear I can get an entire vacuum line set for it as well as where I can find the routing for the lines?
Old Sep 2, 2014 | 11:17 PM
antares57's Avatar
Car: 91 Firebird/88 Firebird/91 Formula
Engine: V6 3.1/V8 5.0/V8 5.0
Transmission: 4L60/700R4/4L60
Axle/Gears: 3.23/2.73/2.73
Re: Help... vacuum leak? replacement vacuum lines
I got my lines , by the foot, at Auto zone. The link below should have all the info you need to connect it right. Good luck.
https://www.thirdgen.org/forums/tech...iagrams-i.html
Old Sep 2, 2014 | 11:19 PM
91 camaro racer's Avatar
Car: 91camaro rs,2014 silverado 5.3L
Engine: 5.7Lcarb,5.3L
Transmission: 700-r4, 6L80
Axle/Gears: strange 3.73's
i would just go to the auto parts store it get it in bulk. maybe like 10 feet or something
Old Sep 12, 2014 | 09:04 PM
jstratouly's Avatar
Car: 88 Iroc Z28
what is the dimensions of it. ive seen 3mm or 8mm for the tubing when i look it up for the camaro
Old Sep 12, 2014 | 09:21 PM
Take a piece of the line you want to replace; match it up to what's hanging on the cards.
Most of it (in the US at least) isn't in mm; it's in 1/32 of an inch.
Keep in mind also, most of it doesn't have to be the "exact" size; the factory used a lot of what they used out of pure convenience, as opposed to, some functional consideration; if they have the fittings you need but with a notch or 2 different size of line, most of the time you can make it work.
Stick with the hard plastic type as much as practical, but don't be too reluctant to use the rubber kind either. Just make sure that there's no leaks at the junctions. (use the spring type clamps, or twisted wire, or the like)
specialized
Jun 18, 2022 09:26 AM
jklein337
Sep 19, 2018 06:23 PM
Infested
May 22, 2018 11:56 PM
cstrobel65
Aug 15, 2015 10:19 AM
