adjusting timing on tpi
Old Sep 8, 2014 | 11:56 AM
Black88Z's Avatar
Car: 1988 IROC-Z Camaro, 1981 Trans Am
Engine: 350 TPI, 301 N/A
Transmission: 700r4, 350thm
I have read where you can unplug the connector that allows the computer to adjust timing and adjust base timing. I know factory base timing is 6 degrees. I've read several people saying you can bump the timing up to 12 on a stock ish engine and it'll be ok, any more and it's to much. My engine is fairly stock, some bolt ons, an exhaust, and opening up the air intake big time. I was thinking of go with 10 degrees bar, to keep it on the safe side.
I've been reading lately that if you adjust base timing this way, it somehow hurts performance. It doesn't make sense to me, but I figured I'd check with you guys on it first. Should not make a difference, but its the 350tpi.
Old Sep 8, 2014 | 12:46 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Re: adjusting timing on tpi
I suggest you try 8 first, and move in 2 degree increments.
Mine will ping over 8.
Edit:
It's possible that some are getting knock retard from pinging, with too much base timing,
Old Sep 8, 2014 | 06:09 PM
Black88Z's Avatar
Thanks for the advice. did you notice any difference? (probably not at just 2 degrees lol)
Any one else have any input?
Old Sep 8, 2014 | 10:06 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Didn't notice anything, I'd just set it at 8 years ago, once I found the EST connector and learned how to check/set the timing, pretty sure I set it back to 6 for smog teasting, and just left it.
The majority, if not all of, your performance is done via PROM tuning.
Old Sep 9, 2014 | 11:44 AM
Black88Z's Avatar
right. I plan to order a chip from a man named John Wayne who custom burns them, I've been hearing good things about the chips he sells.
Old Sep 9, 2014 | 09:33 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
I talked to some burners, not a lot of gain on a stock set up....just saying, wish TP was still here.
Old Sep 9, 2014 | 09:42 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Is this the guy on FB? I haven't heard much good. I wouldn't waste time with a aftermarket chip until you do way more.
Bump the timing,use highest octane you can, (93) and fuel PSI along with other "free mods" will help more than another chip. (do it at the tack for best results)
Old Sep 9, 2014 | 09:57 PM
IROCgiraffe's Avatar
Car: '87 IROC-Z | '99 SS
Engine: LB9 | LS1
Transmission: 700R4 | T56
If you need a tune... "Tuned Performance" is the man.
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Sep 17, 2020 08:26 AM
Infested
May 22, 2018 11:56 PM
86IROC112
Aug 17, 2015 02:00 PM
Sanjay
Aug 12, 2015 03:41 PM
