Any idea how many horses?
Old Sep 9, 2014 | 08:59 AM
82z-28/92Rs's Avatar
Car: 82 Z-28
Engine: built 350
Transmission: TH350
Axle/Gears: 2.90
Im new to the internet forums so please bear with me. I have a 350 .060 over with summit flat top pistons and a 272TL-6 Comp cam. 041 chevy heads with 2.02 intake and 1.60 exhaust with bigger upgraded springs and pinned studs. 1.5 roller rockers with stud girdles. Edelbrock performer intake and edelbrock 600cfm carb. Anyone running something similar? Just need a guesstimate on how much power Im lookin at..all help is appreciated.
Old Sep 9, 2014 | 01:22 PM
truckerz's Avatar
Car: 1989 Formula
Engine: 355ci HSR SBC
Re: Any idea how many horses?
I ran a cam quest dyno on your setup. It is fairly liberal (10-20%)
I have assumed you have shortie headers with no cat, but an attached muffler. Depending on the port work on the heads, you are looking at 375-425hp (-10 TO 20% BASED ON THE LIBERAL NATURE OF CAMQUEST)
I would guess that your acutal power falls around 340-400hp at the crank.
It may be off, but my combo says 475hp at the crank on Camquest, and there is no way mine makes 400whp. It is more like 440hp at the crank and 350 or 360 at the wheels.
If you want to play with the program go to www.camquest.com.
It isn't perfect by any means, but it will give you food for thought.
Old Sep 9, 2014 | 05:13 PM
Car: 82 Z-28
Engine: built 350
Transmission: TH350
Axle/Gears: 2.90
Thx alot!
Old Sep 9, 2014 | 06:49 PM
Car: 82 Z-28
Engine: built 350
Transmission: TH350
Axle/Gears: 2.90
11qaqqq qasRe: Any idea how many horses?
And silly as it is..I do have a cat with pipes lol. Sounds decent for 2.5 inch. And what size carb should I be running?
Old Sep 9, 2014 | 09:48 PM
DeltaElite121's Avatar
Car: 1988 Camaro
Engine: 377
Transmission: TH350; Circle D 4200 converter
Axle/Gears: Ford 9"
Anything away from an Edelbrock if you actually want it to perform anywhere near reasonable. 750 with manual secondaries.
Old Sep 10, 2014 | 11:53 AM
Car: 82 Z-28
Engine: built 350
Transmission: TH350
Axle/Gears: 2.90
And is the 2 1/2 pipe gonna be to small? Also im in n.c and have to have catalytic converter for the safety part of inspection so would gutting it and reinstalling be good or bad? And can the carb really melt down the cat?
Old Sep 11, 2014 | 08:14 PM
Car: 82 Z-28
Engine: built 350
Transmission: TH350
Axle/Gears: 2.90
Hey truckerz is there any way you can run my setup again please? New intake and carb on order so id like to see of any better. Specs are 350 .060 over with flat tops, 041 heads with minor port work with 202 160 valves and big springs. 272TL-6 cam with 1.5 rockers and victor jr intake and holley 750 double pumper. Shorty headers and 2 1/2 in exhaust with cat and muffler. Thanks in advance and all hints or info is much appreciated!!
Old Sep 12, 2014 | 06:23 AM
truckerz's Avatar
Car: 1989 Formula
I will when I get home. I'd drop the cat and get a high flow muffler. ... or get rid of the muffler all together. You have short tube headers, long tubes, or manifolds? Is your intake ported? Single plane or dual plane? Minor port work on the heads will help, and the valves at good, but power is in the head. If it's in your budget, pick up some afr. Or profiler 195s. They flow way way better than the 041s. Duh. .... missed the details in your last post. ....Victor Jr and shorties. ....
Old Sep 12, 2014 | 06:35 AM
truckerz's Avatar
Car: 1989 Formula
http://www.nastyz28.com/forum/archive/index.php/t-214307.html
Check this link out for carb selection...
Old Sep 12, 2014 | 06:33 PM
truckerz's Avatar
Car: 1989 Formula
I got 425hp. 422tq. Your heads kill it.
You could get 475 hp 450 tq by getting some good heads. Aside from that, cutting your cat out. .... or installing a exhaust cut out in front of it, Quest says 466 hp 462tq. With your current heads. Again. .... This is just guesswork. There are lots of other things that make horses.
Old Sep 12, 2014 | 07:20 PM
Car: 82 Z-28
Engine: built 350
Transmission: TH350
Axle/Gears: 2.90
Any ideas to better my setup aside from new heads?? Some nicer alum. heads are coming in the near future but gonna run the 041s for now.
Old Sep 12, 2014 | 07:39 PM
Car: 82 Z-28
Engine: built 350
Transmission: TH350
Axle/Gears: 2.90
Any ideas to better my setup aside from new heads?? Some nicer alum. heads are coming in the near future but gonna run the 041s for now. And was my hp/tq 425/422 or 466/462? Thanks for all your help!!
Old Sep 12, 2014 | 08:38 PM
truckerz's Avatar
Car: 1989 Formula
466 was the no cat or no muffler.
A proper tune. If et is important, drag radials. Ultra pro mag rockers. Would help. What is your goal?
Old Sep 12, 2014 | 08:41 PM
truckerz's Avatar
Car: 1989 Formula
Lca, torque arm, wonder bar, springs. Good tires, fiberglass hood. Subframe connectors . Basically lightening the car and strengthening the frame.
Old Sep 14, 2014 | 12:15 PM
Car: 82 Z-28
Engine: built 350
Transmission: TH350
Axle/Gears: 2.90
Ok thx a lot!
gta892000
Aug 11, 2019 11:16 AM
Nick McCardle
Sep 10, 2015 08:36 PM
Djmathis123
Sep 8, 2015 08:42 PM
z28guy134
Sep 1, 2015 11:50 PM
