Firing order for Distributor Cap/wires
Old Sep 15, 2014 | 07:50 PM
oxygen454's Avatar
Car: 1988 Firebird
Engine: 5.0L
My friend that was helping me do some engine work decided to pull the wires off the cap before I could number them all.... 1988 firebird 5.0L
Thanks in advance.
Old Sep 15, 2014 | 07:55 PM
RamIt's Avatar
Car: 1984 z28
Engine: Crate replacement L31R 350
Axle/Gears: 7.625" 28 spline 3.23
Re: Firing order for Distributor Cap/wires
18436572
Old Sep 15, 2014 | 08:07 PM
oxygen454's Avatar
Car: 1988 Firebird
Engine: 5.0L
Great thanks!!
Old Sep 15, 2014 | 09:21 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
#1 is usually in the 5 o'clock position when looking at the cap from the front. Rotation is clockwise
Old Sep 16, 2014 | 07:16 AM
MoJoe's Avatar
Car: 87 IROC
Engine: L31 350
Axle/Gears: 4.10 D44
Good advice. You did say "usually", which means ...
@Oxygen454 - #1 could be anywhere. It depends on what else you and any Previous Owners have done, whether that rule of thumb still applies.
Rotate the balancer mark to TDC. The distributor is pointing at either #1 or #6. You can search on how to determine which one.
Old Sep 16, 2014 | 07:56 AM
oxygen454's Avatar
Car: 1988 Firebird
Engine: 5.0L
Luckily when I numbered the first 4 wires with tape near the cap, I took a picture. So I shouldn't have a problem now that I have the firing order. Thanks!
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
64goatman
Sep 9, 2015 01:09 PM
Jlanz55
Sep 9, 2015 09:09 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
