cam choice
Old Oct 2, 2014 | 04:15 PM
ocelot729's Avatar
Car: 90 Firebird T/A
Engine: TPI 350
Axle/Gears: Posi-2.73
cam choice
I'm Building A Drift Missile Outta My T/A. Got A Brand New Cam From A Friend, But It's A .534 Lift, 245 In/Out, Advertised 295 In/Out. Would This Be A Good Cam Or No? It Will Be On The Street At Times As Well.
Old Oct 2, 2014 | 09:56 PM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Re: cam choice
on what motor?
what induction?
what trans?
what supporting mods?
what type of cam is it?
Please include part numbers and supporting information
Old Oct 3, 2014 | 12:03 PM
ocelot729's Avatar
Engine: TPI 350
Re: cam choice
Sorry, Was Doing This On The Phone And It Hates Me. 350 Chev, Going To Put Vortec Heads, I'm going to switch over from fuel injection to a carburetor, and also it's going to be the stock 704 I'm going to have rebuilt, I'll should change the rear gear out to probably a 4.11 Ratio... as for the cam its a flat tappet cam not a roller cam.
Old Oct 3, 2014 | 12:05 PM
ocelot729's Avatar
Engine: TPI 350
Re: cam choice
http/Www.summitracing.com/parts/lun-07103lun
Old Oct 3, 2014 | 12:27 PM
midias's Avatar
Re: cam choice
I am not seeing any part of this plan that is a good idea when you combine the pieces.
To take advantage of that cam the heads will need some serious work, the bottom end should be rebuilt and balanced. You will need a decent stall.
4.11s with 700r4 is going to give you 70 at about 3k rpm
EFI to a carb is a bit of a downgrade
Roller to flat tappet is a major downgrade.
That cam is not going to be super streetable.
Old Oct 3, 2014 | 01:47 PM
aliceempire's Avatar
Transmission: T-5, TH350, T-5
Re: cam choice
Especially the roller to flat tappet downgrade...bad idea.
Old Oct 3, 2014 | 02:09 PM
ocelot729's Avatar
Engine: TPI 350
Re: cam choice
Not Gonna Be A Street Car Anymore, And I Have No Want For EFI. I Am Planning To Go Into The Bottom End, And Was Planning 3.73 Gears But I Was Told To Go Higher. Don't Know Why. the Vortec heads that I've gotten from the machine shop have already been cleaned up shaved as well is gone completely through they were meant to be a circle track race car..
350 IROC-Z
Camaros Wanted
Dec 18, 2015 03:58 PM
Jorlain
Oct 8, 2015 01:57 AM
fbodyfreakls1
Oct 6, 2015 06:34 PM
ericjon262
Sep 11, 2015 06:07 PM
scottmoyer
Sep 7, 2015 07:06 PM
