LOL--- watch out for AUTOZONE Ignition Wires
Old Oct 5, 2014 | 04:43 PM
Zink57's Avatar
Car: 1987 IROC Z
Engine: LB9
Transmission: 700-4R
My high mileage IROC is up for SMOG check (CA) soon.... so the other day I put on a fresh set of plugs (as stated by my other post) and decided to replace the wires for the test. Of course NAPA's premiums were out of stock so I took a chance and stuck some new AUTOZONE wires on it with the intention of changing them out in a couple months... Step dad- whose a mechanic stops over to pick up something at my house unrelated and I tell him about my SMOG check plans.. he says let's check the timing so of course I'm like YES PLEASE!!!
As we set TDC #1 at stock timing 6 deg BTDC we noticed that it was "back firing" around 2000 rpm Step dad pulls off the coil wire to check the quality of the spark and on the connected end by the coil we were astonished to see SPARK arc'ing from behind the plug boot and the wire. We weren't pulling the wire or stretching it.. it was just arc'ing on it's won. As soon as I put on my old wire set's COIL wire all was well and the mystery "backfire" was a thing of the past.
SO CAUTION.. with that AUTOZONE crap! The wires were literally BRAND NEW! And another thing.. I wasn't running a HIGH OUTPUT Module or ignition system so that whole arc'ing crap is BS on a stock ignition
Old Oct 5, 2014 | 09:55 PM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Re: LOL--- watch out for AUTOZONE Ignition Wires
Here's a decent set at a decent price.
I've been told they are rebadged Taylors, and I've been using them for years. Not only that but Summit Racing is one of my favorite places to buy aftermarket parts.
Here's the link for yours= http://www.summitracing.com/search/y...6%2B4294926275
Old Oct 5, 2014 | 10:18 PM
88Camiroc's Avatar
Car: 88 iroc
Engine: 350 4-bolt main 010 bored .040 over
Transmission: t-5 manual
Here's the link for yours= http://www.summitracing.com/parts/sum-868858r/overview/
I will agree i will only get my parts (if they carry them) from summit racing. I HATE with a very strong passion AUTOZONE. I have had nothing but problems from there parts. The only thing i will get from the are the gatorback serpentine belts. so for sure go summit.
Old Oct 5, 2014 | 11:01 PM
Engine: TBI,5.0
Have them through this in while your at it.
= http://www.summitracing.com/parts/ad...t/model/camaro
and
= http://www.summitracing.com/parts/ms...t/model/camaro
and
= http://www.summitracing.com/parts/spe-4244/overview/
Summit has never charged me tax or shipping on any of my orders but there is a $9.95 handling fee.
That's why its best to order everything you can at one time. Its a one time fee and they have some of the FASTEST shipping I've ever seen.
They even price match including with Rockauto.
Old Oct 6, 2014 | 07:34 PM
cuisinartvette's Avatar
Car: 67 ******mobile
Engine: 385 Solid roller
Axle/Gears: 4.11
Ive used those Summmit wires for yrs had good luck I was told they were MSDs who knows
Keep a set of cheapie wires around in case I burn one up on the road somewhere
Old Oct 6, 2014 | 09:37 PM
88Camiroc's Avatar
Car: 88 iroc
and
and
And that would be the exact reason i use Summit for everything!
Old Oct 6, 2014 | 09:43 PM
Night rider327's Avatar
Car: 1988 Camaro
Have yall ever ohm'ed out the summit wires? I would be really interested in seeing how many ohms per foot they are.
I run MSD 8.5mm for the low 40-50 ohms per foot.
Old Oct 7, 2014 | 03:22 PM
Zink57's Avatar
Car: 1987 IROC Z
Engine: LB9
Thanks for the recommendation of the Summit wires... I ordered them in blue and should be getting them anytime soon...!
Old Oct 7, 2014 | 07:29 PM
Axle/Gears: 4.11
They are supposed to be 50 I should check mine gettingready to replace them
Seem fine after 3 yrs but lost a boot due to a header sogot an Oreillys on #7
Old Oct 7, 2014 | 07:34 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
I have used the Summit wires for maybe ten years, at least 8. I always purchase the set that allows you to cut the wire to length and crimp on the ends. My first set lasted several years, five or so, until one day when I was playing with the timing I noticed I was getting zapped when I touched the distributor! I immediately purchased another new set. Just beware that the rubber around the boots at the distributor may dry out in a few years.
BRoss99
Aug 10, 2025 05:08 PM
Caspar
Jun 19, 2016 11:19 PM
Hellbillydeluxe
Sep 22, 2015 09:58 PM
Rakim_RS25TH
Car Audio
Aug 20, 2015 06:22 PM
Rakim_RS25TH
Aug 18, 2015 09:32 PM
