Gas Tanks The Same For All Thirdgens?
Old Nov 8, 2014 | 09:45 PM
kx3g's Avatar
Car: '89 Formula
Engine: L98 350
I did some searching and couldn't find the answer. I need to replace my gas tank. Are all thirdgen tanks interchangeable except for maybe the 1LE?
Old Nov 9, 2014 | 12:13 PM
rusty vango's Avatar
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
Re: Gas Tanks The Same For All Thirdgens?
a suggestion, don't buy a "spectra" brand replacement. they are quite cheap ,and do not fit right out of the box. I would get a good used one. as for 82-92 being all the same, it appears so.
Old Nov 9, 2014 | 04:51 PM
kx3g's Avatar
Car: '89 Formula
Engine: L98 350
Thanks for the reply Rusty. My car has an aftermarket tank in it now that the PO put in. I suspect it is a Spectra. I'm going to try to find a good original tank to put back in.
I see you are from Knoxville. What part of town do you live in?
Chris
Old Nov 9, 2014 | 07:19 PM
Car: 86 IROC
Engine: 5.0 TPI
Chris
south, just across the gay st bridge on mimosa ave. hit me up, if you ever need a hand.
Old Nov 9, 2014 | 08:42 PM
RamIt's Avatar
Car: 1984 z28
Engine: Crate replacement L31R 350
Axle/Gears: 7.625" 28 spline 3.23
A question for the more knowledgeable.
Spectra list 2 different tanks for the thirdgens. one with a pan in the tank and one without.
Did the fuel injected cars only get the pan in the tank or was it a rolling change?
Old Nov 10, 2014 | 10:46 AM
Car: 86 IROC
Engine: 5.0 TPI
ok, my knowledge is this. go ahead with a spectra tank, BUT youll be sorry you did. a total waste of time and money. as for internal diffrences there are only two that im aware if .the "1-LE" and everything else. your money will be better spent finding a good used tank.
Old Nov 10, 2014 | 11:30 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
In 90 or 91 gm started putting the baffled "1LE" tank in all the cars so start your search there.
Old Nov 10, 2014 | 05:36 PM
kx3g's Avatar
Car: '89 Formula
Engine: L98 350
Ttop350, Are you saying a '90/'91 can be used in my '89?
Old Nov 10, 2014 | 07:10 PM
TTOP350's Avatar
Yup. Its what I have in both my 89 formula 350 cars
Old Nov 10, 2014 | 08:32 PM
kx3g's Avatar
Car: '89 Formula
Engine: L98 350
Thanks Top. The search begins.
Old Dec 23, 2014 | 08:28 PM
kx3g's Avatar
Car: '89 Formula
Engine: L98 350
I'm picking up a tank out of a '91 camaro this weekend so it should have the baffles. Can I use the fuel pump, sending unit, etc. from the tank in my '89 in the '91 tank?
Old Dec 24, 2014 | 07:55 AM
Car: 86 IROC
Engine: 5.0 TPI
the hole that the sending unit goes in appears to be the same. obviously, the sending units are different.depending what fuel system you have (carb,TBI,TPI)
Old Dec 24, 2014 | 11:12 AM
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
So TBI and TPI openings are different, eh? I did not know that. Learn something new every day around here.
Old Dec 24, 2014 | 04:04 PM
Barlow8869's Avatar
Car: 1989 IROC-Z / T-Top -1987 GTA
Engine: 305 (LO3) _350 (L98)
Transmission: 700R4 _ 700R4
Axle/Gears: 2.73 L.S. - ???
opening should be the same ... it's what is inside that would be different
Old Dec 25, 2014 | 10:26 AM
PurelyPMD's Avatar
Car: 1987 IROC Original Owner
Engine: LB9
Transmission: M39 MM5
Axle/Gears: G80 G92 J65
Is there a part number, tag or any kind of coding that will help you determine which tank you are getting in the 90-91's? I'd like to put one of the baffled tanks in my 87 but want to be sure what I'm getting before I go through the trouble.
Old Dec 25, 2014 | 10:48 AM
swiss's Avatar
Source a plastic one from a fourth gen, way better part.
Old Dec 25, 2014 | 11:42 PM
Car: 86 IROC
Engine: 5.0 TPI
a no go as you have to modify the car to do that . they are not a direct fit
Old Jan 1, 2015 | 09:02 PM
kx3g's Avatar
Car: '89 Formula
Engine: L98 350
Didn't get the tank over the holidays. The guy getting the rearend didn't get it pulled. It will be a few weeks.
So as long as the 90/91 tank is from a TPI car, the sending unit and fuel pump from my 89 TPI car should work in it? Am I understanding this correctly?
Old Jan 1, 2015 | 11:01 PM
Car: 86 IROC
Engine: 5.0 TPI
yes
Old Jan 2, 2015 | 10:58 AM
kx3g's Avatar
Car: '89 Formula
Engine: L98 350
Thanks Rusty
Old Jan 2, 2015 | 12:36 PM
Car: 86 IROC
Engine: 5.0 TPI
Thanks Rusty
anytme, if you need a hand (and its always a good idea to have help with these kinds of things)or any other help, you can give me a call@ 865-603-4120. i see youre also in knoxville. lets hook up
Old Jan 14, 2015 | 11:19 PM
89FormulaDan's Avatar
Even with the rear out of the car, you need alot of ground clearance to remove/install tank without bending the filler neck.
Old Jan 14, 2015 | 11:27 PM
I complained to GM, when my 89 Formula 350 was new, that on long hard right turns my engine would cut out if tank was less than 1/4 full. They would not admit that this was a design problem that the 1LE baffled tank solved. Once the car slowed down in the turn (less g-force) the engine would come back to life and if I accelerated again it would sputter and die! Tried unsuccessfully to get them to upgrade me to a 1LE tank. They said it was only necessary for racing.
Old Jan 15, 2015 | 11:38 AM
DynoDave43's Avatar
Originally Posted by 89FormulaDan
...that on long hard right turns my engine would cut out if tank was less than 1/4 full.
I've experienced this twice with my T/A. Got my attention the first time it happened.
Old Jan 16, 2015 | 11:00 AM
Hey Dave,
I LOVE on/off ramps!
The feeling of g-force is like a drug to me. (haha)
One of the few places you can test the capabilities of these cars... although I did get pulled over once when a highway cop was parked out of sight on an off ramp posted at 25mph. I buzzed by him at about 55! Guess he was pissed I went by so fast he couldn't read my sticker!
Old Jan 16, 2015 | 03:48 PM
DynoDave43's Avatar
I LOVE on/off ramps! The feeling of g-force is like a drug to me. (haha)
I know! There's a particular series of ramps that I take when I drive to work...have only driven the T/A to work a couple of times, but taking those ramps is a hoot! By far the best handling car I've ever owned.
..although I did get pulled over once when a highway cop was parked out of sight on an off ramp posted at 25mph
Oops.
Old Jan 17, 2015 | 06:18 PM
90 GTA Black's Avatar
This thread has the listing of all gas tank #s including 1le. Hopefully the link works:
https://www.thirdgen.org/forums/body...llons-3rd.html
Old Jan 17, 2015 | 07:35 PM
Car: 86 IROC
Engine: 5.0 TPI
from bone dry, mine holds 16 US GALLONS
Infested
May 22, 2018 11:56 PM
Andrew6.688
Dec 13, 2015 10:59 AM
mustangman65_79
Sep 1, 2015 03:51 PM
AkDrifted
Aug 17, 2015 07:45 PM
kyleb24
Aug 15, 2015 08:24 AM
