350 Losing Oil Pressure
Old Nov 12, 2014 | 10:26 AM
Carbed350's Avatar
I have an 88 Camaro that I swapped to a carbureted 350 over the summer. The engine was professionally rebuilt and installed by me. After install I waited about 500 miles and changed the oil and filter. It was about another 500 miles or so, and the oil pressure gauge started acting up, dropping completely to 0 psi and then jumping back up to normal. I didn't think much of it at first, it's an old car and has the potential to have a gauge malfunction. I kept driving it, and things went well until the engine started making noise. I immediately killed the engine and had it towed home. I changed the oil and filter, started it up and it ran like a champ! I figured maybe the filter was plugged from small debris during break in. About another 500 miles later same story! With fresh oil everything is great, she runs wonderfully, but it only takes about 500 miles and I'm having to change it again! Any info would be greatly appreciated!
Old Nov 12, 2014 | 11:13 AM
86LG4Bird's Avatar
Car: '86 Bird, 96 ImpalaSS, 98 C1500XCab
Engine: LG4, LT1, L31
Transmission: 700R4, 4L60E, 4L60E
Axle/Gears: 3.73 Tors, 4.88 spool, 3.73 Eaton
Re: 350 Losing Oil Pressure
The pickup could have fallen off the pump (unfortunately, not unheard of with fresh rebuilds). After an oil change, the level is still high enough in the sump to cover the pump inlet. 500 miles later, a little bit of oil consumption, and the level drops just low enough to momentarily uncover the inlet.
Old Nov 12, 2014 | 11:40 AM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
That would be his best outcome. A rebuilt motor having to be re-done again would be bad
Old Nov 12, 2014 | 11:52 AM
mlbinseattle's Avatar
Car: '84 Camaro Z28
Engine: 305 HO
Sounds like it's time to drop an oil pan to take a looksee.
Old Nov 12, 2014 | 12:13 PM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Does pressure drop more often when you brake or turn?
Old Nov 12, 2014 | 01:38 PM
Car: '84 Camaro Z28
Engine: 305 HO
Normally, it shouldn't drop below 30, maybe a little less, provided the oil level is correct and isn't thin from being old or way too hot. If it's dropping to 0 and then jumping back up, there's cause for concern. Even if it's a quart low, it shouldn't be doing that.
Old Nov 12, 2014 | 01:55 PM
Car: '84 Camaro Z28
Engine: 305 HO
The fact that it started making noise when this started should be cause for concern. It's possible that the pickup fell off or a mounting bolt worked it's way loose and fell out. The pump may be sucking air at the gasket area at times during turns or breaking. You won't know for sure until you drop the pan and look.
Old Nov 13, 2014 | 04:00 PM
Carbed350's Avatar
I looked more into the possibility of the pickup having fallen off and it seems like that is the case, all of the symptoms that others have described when having that issue match-up with what I've been experiencing. That will at least give me somewhere to start looking. Thanks everyone for your input!!
Old Nov 13, 2014 | 04:01 PM
midias's Avatar
You may want to consider welding it to the pump next time.
Old Nov 13, 2014 | 04:03 PM
Carbed350's Avatar
I will certainly do so, hopefully that's the issue!
89GTAOz
May 16, 2020 09:31 AM
355sbcTPI
Aug 19, 2015 04:38 PM
bamaboy0323
Aug 15, 2015 07:20 AM
ChevyZ71
Aug 13, 2015 07:30 AM
