89 5.0 TBI stalling when coming to a stop
Car: 1988 Camaro
Engine: 305 TBI
Transmission: WC t5
Axle/Gears: Stock
Hello, it's been a long while since I posted here, or even had a camaro. It's time to get one again. I found a sale of one for cheap and everything. But the owner says it stalls when coming to a stop. What are some possible causes of this or common problems? I'm thinking maybe the IAC, or vacuum leak? chime in, thanks!
Car: 86 Trans Am
Engine: 305 LB9
Re: 89 5.0 TBI stalling when coming to a stop
If everything else is decent I'd say its the IAC. You can clean it with a special cleaner. I never have luck with that so I did the mortal sin and bought one on eBay for like 20 bucks for a off brand part. Popped it in and that solved my issue. Will it last. That's to be debated.
Car: 86 Trans Am
Engine: 305 LB9
Also check to see if the ses light is on. Moderate vacuum leaks with cause a lean condition and flip a light and you can usually hear them while its running
