cam which one?
Old Dec 24, 2014 | 04:15 PM
bull600's Avatar
Car: chevelle
Engine: 350 tpi
Axle/Gears: 3.55 12 bolt
cam which one?
I have a 69 chevelle with a holley stealth ram. I am building a 99 vortec block 5.7 engine. I have a set of promaxx maxx heads (9183) 10.5 compression with flat tops headers and a 411 ecm i have a 700r4 trans with a small stall and 3:55 gears. I need a new cam and injectors i know i will have to tune again also with all that said i want a fun street car dont care about power at 6000 the car will probably live around 1500-3000 ish my thoughts have been a gm 846 cam or lt4 hot cam comp said a xr269 just looking for input.
Old Dec 24, 2014 | 07:55 PM
Re: cam which one?
XR269 sounds a bit conservative, but OK. If you get that, get it as the "502" grind. http://www.summitracing.com/parts/cca-08-502-8 Might want to also consider the "503", the next step up. The 846 (a Crane product actually) isn't too bad. Any of the above will be more to the point than the HOT cam.
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
Strick1
Sep 4, 2015 07:11 AM
z28guy134
Sep 1, 2015 11:50 PM
