Need opinions
Old Jan 9, 2015 | 08:58 AM
firebirdfreak87's Avatar
Car: 87 firebird did V8 swap
Engine: sbc 350
Transmission: 700r4 shift kit and stall
Need opinions
Ok I got a sbc 350 stock bore and stock pistons got 906 vortec heads ported and polished gonna b buying four barrel intake I need opinion on what cam and carb I should run looking for a fun street and strip car
Old Jan 9, 2015 | 09:26 AM
RedLeader289's Avatar
Car: 1983 Z28
Engine: 385 Fastburn
Re: Need opinions
with no more info I'd say Holley 650 DP.
Old Jan 9, 2015 | 09:41 AM
Engine: sbc 350
Re: Need opinions
Ok any ideas on a cam
Old Jan 9, 2015 | 09:43 AM
Car: 1983 Z28
Re: Need opinions
Nope, to be totally honest I'm still figuring out what makes a good cam myself. There's way more knowledgeable folk on here about that than me so here's hoping they chime in.
Some specs on those heads would help to make that decision though.
Old Jan 9, 2015 | 11:30 AM
86LG4Bird's Avatar
Car: '86 Bird, 96 ImpalaSS, 98 C1500XCab
Engine: LG4, LT1, L31
Transmission: 700R4, 4L60E, 4L60E
Axle/Gears: 3.73 Tors, 4.88 spool, 3.73 Eaton
Re: Need opinions
What TC stall rpm? what rear gearing? what compression ratio?
Old Jan 9, 2015 | 11:56 AM
2005Impalla's Avatar
Car: 86 Z28 T-Top
Engine: Vortec 350
Axle/Gears: I think 3.73 open dif
Re: Need opinions
I would run a RPM air gap, Holley 650 DP carb, comp cams Xtreme 274 cam, a 2,500 RPM stall, 3.42 or 3.73 gears.
Old Jan 9, 2015 | 05:39 PM
rusty vango's Avatar
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
Re: Need opinions
stay away from a holley carb UNLESS youre the type that likes to dink with things more than just drive it
Old Jan 10, 2015 | 12:11 PM
Engine: sbc 350
Re: Need opinions
I have 2500 stall I haven't bought rear gear yet with that setup u said impala what u think I'll b pushing power wise
Old Jan 10, 2015 | 05:52 PM
Car: 86 Z28 T-Top
Engine: Vortec 350
Re: Need opinions
Well according to comp cams web page they pulled 369 HP using dart SR heads 9.25 compression an edelbrock performer intake and a 750 vacuum sec carb. I don't know if there full of #@$% or not but you would be running better heads, intake and a carburetor better matched to the set up with probably just a little more compression so if I had to take a guess I would say some were between 375 and 400 HP.
Old Jan 10, 2015 | 06:03 PM
Car: 86 Z28 T-Top
Engine: Vortec 350
Re: Need opinions
I might even use a larger carb too depending on what gears you go with and if you plan on gutting the car or not. If your car is light and your running the 3.73 gears with a loose stall you might get a little more top end power form a 750 CFM carb. They rate carbs based on a 1.5" vacuum which your car should never pull at full throttle and if you run lower gears and have a light car its best to over size the carb just a little.
If you don't gut the car or lighten it much and run taller gears use the 670 carb.
Old Jan 12, 2015 | 07:00 AM
Car: 1983 Z28
Re: Need opinions
Honestly I would say that if you don't like to tinker with things you shouldn't own a carb'd car at all, haha.
To the OP-> the brand war on carburetors is an endless one. Just do your research (on more than just this forum, go to the manufacturers, magazines, etc) and make your decision.
Old Jan 15, 2015 | 05:46 PM
Engine: sbc 350
Re: Need opinions
It's pretty much gutted except carpet and seats and dash like center console is redone in aluminum not ac or heater box no radio so I'll probally go with the 3.73 gears I have posi for it it was a v6 car I have swapped it and have b&m shift kit in it already to no my bottom end is pretty much stock can it handle a small spray or is that pushing it
Old Jan 16, 2015 | 09:39 AM
Car: 86 Z28 T-Top
Engine: Vortec 350
Re: Need opinions
I have never sprayed a car so could not tell ya. I would like to think it would handle a 100 HP shot just fine. Me, family and friends through out the years have built 6,500 RPM motors suing stock rods, crank and pistons in old 350's and they hold together just fine so if you not pushing the motor to the max a small shot of NOS should be just fine as long as you have the motor set up for it properly. I do think it will shorten the life of the motor quiet a bit. Have had friends use it and it seams to kill piston rings after a while. Being gutted with low gears and small stall converter I would use a 750 carb. A 650 would be a safe choice but I think a 750 would make more power.
Old Jan 16, 2015 | 10:17 AM
Car: 86 IROC
Engine: 5.0 TPI
Re: Need opinions
NO2 is big fun. BUT using it on your DD isn't such a great plan, if youre not careful it will grenade it .and youll have to start all over
Old Jan 17, 2015 | 09:59 AM
Car: 86 Z28 T-Top
Engine: Vortec 350
Re: Need opinions
^ Ya probably not something I would use on a motor l loved. If you have a lot of time and money in to it or it would be hard to replace if you blow it up I would skip on the idea.
Old Feb 6, 2015 | 07:35 PM
Engine: sbc 350
Re: Need opinions
It not a daily been project car build for street strip got a 750 double pumper for free a week ago now I just got to find a cam I am leaning to a summit can cause its cheaper and I don't have to much money but I won't spray it cause really don't want to hurt my engine until I can afford a 383 or something else
Pac J
May 17, 2020 10:44 AM
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
cheesehomer
Dec 31, 2015 08:48 AM
skinny z
Oct 5, 2015 06:23 PM
Jlanz55
Sep 29, 2015 08:55 AM
