Engne Oil Temp Sensor and a Canton 15-244T Oil Pan
Old Jan 10, 2015 | 01:53 PM
BWilcox's Avatar
Car: 87 IROC
Engine: 420 EFI
Transmission: TKO500
Axle/Gears: Moser 9" 3:50
Hi Guys,
I just finished a project to install an EOT in my oil pan.
Running a 7730 SD ECM and desired to monitor the EOT.
There are two ways to install a sensor in this oil pan.
1.
Install the EOT sensor in a horizontal orientation on the drivers side.
2.
Install the EOT sensor in a vertical orientation on the passenger side.
I choose option 1 because I am running an aftermarket gear reduction starter. Not much room on the passenger side.
The parts list is not long.
A.
20mm-1.5 Drain Plug : Dorman 65221.
B.
EOT Sensor : Wells TU225 or BWD S8500.
C.
EOT Sensor Pig Tail : BWD PT217 or Dorman 84598.
Drill and Tap the Dorman Drain Plug for a 1/4"-18 NPT Thread.
The last step is to bore the 1/4"-18 threaded hole so the non-threaded part of the EOT sensor body can slide into the modified Drain Plug body.
That's it.
Attached is a picture.
Best Regards,
Bruce
Attached Thumbnails Engne Oil Temp Sensor and a Canton 15-244T Oil Pan-img_0159.jpg
Bstrang6
Sep 8, 2015 04:29 PM
Wife'sCar
Sep 5, 2015 08:58 AM
TA8487
Interior Parts Wanted
Aug 23, 2015 01:34 PM
bamaboy0323
Aug 15, 2015 07:20 AM
