Hole punched thru timing chain cover
Old Jan 18, 2015 | 10:38 PM
BG1959's Avatar
Car: 1989 IROC-Z, 1970 Camaro SS
Engine: 5.7
What started out as a simple water pump change took a downturn after discovering the hole behind it. The cam key punched a hole from the inside out. Anyone ever had this happen before? Do I need to replace the cam or can it be tapped back in?
Attached Thumbnails Hole punched thru timing chain cover-wp_20150118_006.jpg   Hole punched thru timing chain cover-wp_20150118_010.jpg   Hole punched thru timing chain cover-wp_20150118_012.jpg
Old Jan 19, 2015 | 02:40 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Hole punched thru timing chain cover
looks like there may have been a cam button that gave loose. Any idea if this has retrofit roller lifters ?
Old Jan 19, 2015 | 07:30 AM
MoJoe's Avatar
Car: 87 IROC
Engine: L31 350
Axle/Gears: 4.10 D44
Is that an LT4 HOT cam, which has the dowel pin length for LT1 engines (~0.600"), and the pin wasn't driven in to ~ 0.300" for use on a SBC?
First time it was fired up, it tore its way through the cover...
Old Jan 19, 2015 | 08:41 AM
BG1959's Avatar
Engine: 5.7
I have no idea of the history of this engine. Bought the car off a trailer not running. Took a lot to get it running to discover this. Previous owner only bought it to turn it around and doesn't know anything about it either. Believe the car was sitting for approx 5 yrs not running or being taken care of.
Old Jan 19, 2015 | 09:27 AM
Engine: Lb9
Transmission: M20
someone has defiantly been inside the engine, the arp bolts are not stock. pull the cover and further inspect.
Old Jan 19, 2015 | 09:30 AM
Engine: Lb9
Transmission: M20
I see the shiny dowel
Old Jan 19, 2015 | 09:32 AM
BG1959's Avatar
Engine: 5.7
That's the plan for later today. Hoping not to have to pull the cam. I'll take more pics and post them.
Old Jan 19, 2015 | 02:54 PM
BG1959's Avatar
Engine: 5.7
Okay, timing cover off, Double Roller timing chain had been installed at some point also. So what's up with that dowel pin sticking out so far? Anyone? Is it something to be concerned about or was the timing chain cover just too shallow for the chain/cam combination?
Attached Thumbnails Hole punched thru timing chain cover-wp_20150119_001.jpg   Hole punched thru timing chain cover-wp_20150119_002.jpg
Old Jan 19, 2015 | 03:16 PM
Engine: Lb9
Transmission: M20
the dowl is out to much, you might want to align the timing dots. Then take the cam gear off and look to make sure the cam stop plate is installed. some lt1/lt4 pin can be taped in but hold a pry bar under the timing gear and tap the pin. This way you wont risk driving the expansion plug out the back of the block. Search sbc timing cover modification you can trim the ears so you can install a new cover without dropping the pan.
Old Jan 19, 2015 | 03:17 PM
Engine: Lb9
Transmission: M20
btw blue locktitie on the cam bolts and torque to 20 ftlbs.
Old Jan 19, 2015 | 03:20 PM
Engine: Lb9
Transmission: M20
http://forums.iboats.com/forum/engin...ng-the-oil-pan
RamIt's Avatar
Car: 1984 z28
Engine: Crate replacement L31R 350
Axle/Gears: 7.625" 28 spline 3.23
It is either a cam for a lt engine or the dowel has worked it's way out. Try taking off the gear and tapping it in. If its too long cut it off. Be aware if you beat it in it will mushroom the dowel and will need some work with a file to fit the gear back on.
Old Jan 19, 2015 | 03:30 PM
BG1959's Avatar
Engine: 5.7
Thanks for the quick responses guys. I'll get back on it shortly and post an update later.
Old Jan 19, 2015 | 03:36 PM
Engine: Lb9
Transmission: M20
Rockauto.com may be a good source for the timing cover just verify where the timing tab is coated.
Old Jan 19, 2015 | 05:48 PM
MoJoe's Avatar
Car: 87 IROC
Engine: L31 350
Using the LT4 HOT cam as the prime example: It was designed as an upgrade for the LT1 to LT4+ specs. The LT1 series of engines drove the optispark distributor off the face of the cam. That is why the dowel stuck out 0.600", which is too far for a plain ole gen I SBC, which needs about 0.300".
I was successful in using a hammer to drive the pin in further, without mushrooming. Or, cut it off with your preferred implement.
Old Jan 19, 2015 | 06:57 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Yup, small punch and drive it in a lil bit. Just need it even or a bit lower than the arp bolts.
Old Jan 21, 2015 | 06:33 PM
BG1959's Avatar
Engine: 5.7
Tried lightly tapping on it to see if it would budge but it didn't. Didn't want to force the expansion plug out. Cut the dowl pin back yesterday. New timing cover arrived today but won't have a chance to install it until Sunday or Monday. Thanks Tuned Performance, MoJoe, Ramlt and TTOP350 for the help.
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
drewdock87
South Central
Aug 18, 2015 09:02 PM
MY87LT
Aug 17, 2015 08:43 AM
