Fast crank trigger to hei module
Old Jan 27, 2015 | 03:02 PM
z 28 jari's Avatar
Car: 1985 Camaro Z-28
Engine: 385
Transmission: th700r4+Edge 2800 stall
Has someone tested this yet,connect crank trigger to hei module pins P and N instead of distributor reluctor pickup.Does it give more stable ignition?With this you can also locate ignition module away from distributor to cooler place.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
gta892000
Aug 11, 2019 11:16 AM
db057
Apr 28, 2019 07:45 AM
MM2Robinson
Oct 1, 2017 09:16 AM
383cam
Sep 9, 2015 06:01 AM
