TDC with piston stop. Lose crank bolt
Old Jan 30, 2015 | 04:24 AM
Alxrez's Avatar
Hey guys. Trying to find TDC using a Piston stop. Problem is when I try to rotate crank back counterclockwise the crank pulley bolt loosens. Would it work if I use the tool first on the compression stroke. Remove the tool rotate some more the insert it again? Would I insert it back on the exhaust stroke?Name:  929510AE-BDC2-483A-B23A-B8BCE9845EE8_zpsuocpk07x.jpg
Old Jan 30, 2015 | 06:32 AM
Re: TDC with piston stop. Lose crank bolt
http://www.summitracing.com/parts/sxt-10000/overview/
http://www.summitracing.com/parts/pro-66782/overview/
Old Jan 30, 2015 | 07:12 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
This tool also
http://www.summitracing.com/parts/lil-23800
I hope that photo isn't what it currently looks like while using a piston stop. The rockers need to be off on the cylinder that the stop is in or the valves will hit the stop. You also need to use a degree wheel to determine where TDC is.
Old Jan 30, 2015 | 08:12 AM
Alxrez's Avatar
Thanks didn't know these exist
Old Jan 30, 2015 | 08:18 AM
Alxrez's Avatar
Originally Posted by AlkyIROC
This tool also
Honestly I have been doing it with out backing off the rockers. I've mostly watched videos on YouTube and not a single one mentioned the possibility of the tool hitting the valves :|. I've only ever installed the tool after putting my thumb over the sparkplug hole and feeling air push my finger off. Should I be worried?
formula_novice
Sep 5, 2015 03:58 AM
gixxer92
Sep 1, 2015 04:32 PM
LT1Formula
Aug 20, 2015 09:36 PM
Dialed_In
Aug 20, 2015 01:45 PM
