NO START! NEED HELP
Old Feb 2, 2015 | 07:48 PM
87-350-5.7's Avatar
NO START! NEED HELP
87 350 tpi. Parked then went to start and it wouldn't fire. Had no spark, replaced ignition control module , still no spark, bought a new accel distributor. Dropped it in and I have spark now. Problem is it wont fire! Replace fuel pump and regulator and fuel filter. Im so close to giving up. This car is my pride and joy and its not longer joyful. Please help. Any legit ideas let me know. Yes iv checked the relay for the fuel pump. Injectors checked out at 16 ohms solid.
Old Feb 2, 2015 | 08:33 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
Re: NO START! NEED HELP
Can you hear the pump turn on when you turn the key forward?
Old Feb 2, 2015 | 09:27 PM
87-350-5.7's Avatar
Yup the fuse is good too. 20 ampfuse
Old Feb 3, 2015 | 09:00 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Was the timing set correctly after the new distributor install? Does it sound like it is trying to start?
Old Feb 3, 2015 | 10:38 PM
Blue_Thunder's Avatar
Car: 1986 Chevy Iroc-Z28
Engine: 1989 TPI 350
Axle/Gears: stock 10 bolt with 2.73 gears
How many threads are you going to make at once dude. This is the third one for the same issue in one day.
Old Feb 4, 2015 | 01:38 PM
87-350-5.7's Avatar
Starts with starter fluid, so I assume its in the correct position
Old Feb 4, 2015 | 01:44 PM
87-350-5.7's Avatar
Thats why im thinking its now became a fuel problem. My manual says the injectors are supposed to read 11-14 ohms. Mine are running 16 ohms with key turned to on position. Im thinking my fuel pump assembly is the problem. Went to junk yard ripped out two in tank assembly that I think were for carberated because the fuel pump isn't in the tank. Question can i run a 12 volt pump on the outside of tank AMD use the assembly I found?
Old Feb 4, 2015 | 04:09 PM
southbay08's Avatar
Did you by any chance check the injectors when they're hot?
Old Feb 5, 2015 | 02:28 AM
87-350-5.7's Avatar
Cant. Won't run but a second from starting fluid. Replacing bad fuel sending unit assembly.. hopefully ill be able to hold 40 psi now.
Old Feb 6, 2015 | 09:36 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
What is the fuel pressure reading?
Orr89RocZ
Apr 25, 2016 08:28 AM
Wade787b
Sep 29, 2015 01:15 PM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
92camaroJoe
Aug 13, 2015 06:07 AM
86Base
Aug 8, 2015 01:34 PM
