which oem roller cam will work on a tpi 350 ?
Car: 89 Iroc,
Engine: 5.7 TPI
Axle/Gears: 327
So Im looking for a roller cam(s). I have 350 tpi motor (two of them) with minor mods done (shorty headers,chip etc). I don't want a radical aftermarket cam.I want smooth idle and performance.I like junk yard shopping on the cheap.So a used oem roller camshaft seems the way to go. I know a 87 -92 TPI cam will work but harder to find used .I herd a LT1 cam will work.How about a truck 96-99 vortec camshaft ( or same as a LT??). Which oem roller will work in my tpi 350?
Car: 1988 Camaro
Re: which oem roller cam will work on a tpi 350 ?
Most stock cams are too small to give any real performance gains. I would think the stock LT4 (not LT4 hot cam) would be about the biggest..
Here's factory cam specs I saved from other message board posts in the past.
stock L31 vortec truck cam specs
Intake lift- .414"
Exhaust Lift- .428"
Intake duration @.050"- 191
Exhaust Duration @ .050" - 196
Lobe Centerline- 111
Factory Camshaft Specifications:
1992 Y-body: 205/207 0.451/0.450 lift 117 LSA
1993-1995 Y-body, F-body: 202/207 0.450/0.460 lift 116 LSA
1994-1996 B-bodies (including L99 4.3L): 191/196 0.418/0.430 lift 111 LSA
1996 Y-body, 1996-1997 F-body: 200/207 0.447/0.459 lift 117 LSA
1996 Y-body, F-body LT4: 203/210 0.476/0.479 lift 115 LSA
LS1 Camshaft Specifications
1998 - 2000 Fbody
202/210 int/exh @ 0.05" duration
0.496" / 0.496" int/exh lift
116 LSA
2001 - 2002 Fbody
197/207 int/exh @ 0.05" duration
0.467" / 0.479" int/exh lift
116 LSA
2001 LS6 cam
207/217 int/exh @ 0.05" duration
0.525" / 0.525" int/exh lift
116 LSA
2002+ LS6 cam
204/218 int/exh @ 0.05" duration
0.551" / 0.547" int/exh lift
117 LSA
GMPP Hot Cam
218/227 int/exh @ 0.05" duration
112 LSA
GMPP ASA Cam
226/236 int/exh @ 0.05" duration
110 LSA
6.0 LQ9
207/196 int/exh @ 0.05" duration
0.479" / 0.467" int/exh lift
116 LSA
5.3 LM7
190/191 int/exh @ 0.05" duration
0.466" / 0.457" int/exh lift
114 LSA
Intake lift- .414"
Exhaust Lift- .428"
1998 - 2000 Fbody
116 LSA
2001 - 2002 Fbody
116 LSA
2001 LS6 cam
116 LSA
2002+ LS6 cam
117 LSA
GMPP Hot Cam
112 LSA
GMPP ASA Cam
110 LSA
6.0 LQ9
116 LSA
5.3 LM7
114 LSA
Engine: 4++,350 & 305 CIs
Stock L98 and LT1-4 are 2close to worry about. The LT4 gets bigger numbers because of the 1.6 roller rockets GM used.
Car: 89 Iroc,
Engine: 5.7 TPI
Axle/Gears: 327
Thanks for the info however Im not really concerned with spec's right now.I just wanted to know what oem roller would physically interchange with a 89 sbc that originally came equipped with a roller camshaft. I wasnt sure if LT1 or LT4 or Vortec truck cams could be installed
Stay away from the truck cams if you can, they will interchange but may not be what you want.
84z96L31vortec
Aug 20, 2017 12:16 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
