air conditioner clutch won't engage
Old Feb 24, 2015 | 09:19 AM
CYNTHIA79's Avatar
Car: 1985 iroc
Engine: 305 tpi
Axle/Gears: 273
air conditioner clutch won't engage so it won't come on. changed valve cover gaskets and tried the ac and nothing. checked continuity across the ac input connector on the unit and it was a dead short. is it fried.
Old Feb 24, 2015 | 09:30 AM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Re: air conditioner clutch won't engage
Couple of things...
1) did you check and see if you pinched a wire under the valve cover?
2) Did it work before the VC change-out?
3) It could be low on freon and not letting the AC Compressor engage. That's a safety feature of the AC unit.
1992 Trans Am
May 10, 2023 07:19 PM
Derick15
Sep 17, 2016 05:28 PM
87 camaro iroc
Aug 20, 2015 07:47 AM
redmaroz
Aug 16, 2015 11:40 PM
rsrmoore
Aug 7, 2015 08:44 PM
