Oil pressure?
Old Feb 25, 2015 | 10:09 PM
85Irocbuild's Avatar
Car: 1988 Gray Iroc
Oil pressure?
Hey all,
I've been rebuilding my 305 over the last month, and replaced the main bearings, rod bearings, rings, lifters, and all the gaskets. I was just priming it with my 1/2 in drill and eventually got oil out of all the rockers on the drivers side and a couple on the passenger side. So I'm feeling pretty good about the oil passages. I hooked a pressure gauge up to it, and was getting about 42 PSI. Is the oil pressure good? I had friend say he had about 65 PSI. Sorry if this question seems minute, but I'm just paranoid about making sure everything is good before I put the motor into the car, especially when it comes to oil pressure. Thanks!
Old Feb 25, 2015 | 10:44 PM
someone972's Avatar
Car: 1991 Firebird Formula
Engine: 5.7L TPI
Re: Oil pressure?
42 psi using a drill should be more than enough oil pressure. I was getting 30 psi on mine with just a regular hand-drill and it pegs at 60 when it's not fully warmed up.
EDIT: Do be sure that the bolts on the cover for the oil pump are tight though. Three out of the four bolts on mine fell out and I was essentially running on near-zero oil pressure for a while there before I could lift the engine to drop the pan.
83 Crossfire TA
Jan 3, 2016 01:26 PM
angel2794
Sep 8, 2015 06:22 PM
Strick1
Sep 4, 2015 07:11 AM
solocus
Sep 2, 2015 12:14 PM
355sbcTPI
Aug 19, 2015 04:38 PM
