changing valve springs
Old Mar 21, 2015 | 01:28 PM
f355bird's Avatar
Car: 1985 Iroc-Z
Transmission: t-5
Question I have changed valve springs before with the compressed air method but was thinking since I'm going to change all of mine would it be easier to just pull the heads and change them? The motor is already taken apart to a long block. It has 47k miles would I have to have the heads resurfaced? Or can I just clean them up like any other gasket surface?
Old Mar 21, 2015 | 05:06 PM
RamIt's Avatar
Car: 1984 z28
Engine: Crate replacement L31R 350
Axle/Gears: 7.625" 28 spline 3.23
Re: changing valve springs
You would just have to clean them up and check for straightness if you took them off.
I have changed a few sets on the engine and just put the piston at tdc on the cylinder I was working on without issues. I never tried compressed air.
customblackbird
Aug 15, 2021 10:16 PM
Cameeeero
Sep 18, 2015 04:00 PM
gta90
Sep 15, 2015 04:00 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
