1985 Iroc z28 code 22
Old Mar 26, 2015 | 08:16 PM
GageBrand's Avatar
Car: 1985 Iroc-z28
Engine: 5.7l TPI
Axle/Gears: Stock
I'm getting a code 22, I replaced the TPS sensor with a brand new one today but I'm still getting a high idle and hard/delay shifts. Also I'm still getting the code after replacing it, what is the next possible issue it could be?
Old Mar 29, 2015 | 11:53 AM
Megaman11's Avatar
Car: 1987 Trans am
Re: 1985 Iroc z28 code 22
Try disconnecting the neg. battery cable for a few
Old Mar 29, 2015 | 02:36 PM
GageBrand's Avatar
Car: 1985 Iroc-z28
Engine: 5.7l TPI
Axle/Gears: Stock
I will give that a shot, I've tried adjusting it also and it still runs terrible, idles high and delayed shifts and bad throttle response. So if the disconnecting the battery cable doesn't work im going to assume its a bad connection
Old Mar 31, 2015 | 03:08 PM
RED85TPI's Avatar
Car: 1985 Trans Am
Axle/Gears: 9 bolt Borg Warner Posi 3.27
If you have a high idle, I would try resetting the Idle Air control valve and adjusting minimum air screw. It's jobs is to allow a minimum amount of air through the throttle body and if it gets stuck open, to much air will be fed through the throttle body which will cause high idling and can cause improper air/fuel mixture.
There is a procedure on this site. You can find it by searching IAC adjustment.
Thornburg
Aug 25, 2015 01:46 AM
drewdock87
South Central
Aug 18, 2015 09:02 PM
Fronzizzle
Aug 17, 2015 02:52 PM
NufNuffZ28
Aug 14, 2015 09:12 AM
Fronzizzle
Aug 9, 2015 01:15 PM
