power steering
Old Apr 5, 2015 | 06:15 PM
GageBrand's Avatar
Car: 1985 Iroc-z28
Engine: 5.7l TPI
Axle/Gears: Stock
power steering
The previous owner of my Iroc put on the wrong power steering brackets, so I have to pull them off and find the ones for the car, my 85 Iroc is a 305 tpi, I also have an 89 RS tbi 305, will the brackets from the 89 work on it? Or where could I find a replacement for it because nowhere seems to sell them
Old Apr 6, 2015 | 06:28 AM
ex-x-fire's Avatar
Re: power steering
Well the 89 will have a serp belt set up so that wont work. Go to the junk yard, might as well swap your 85 over to serp belt style. you'll need a water pump if you go that way.
Old Apr 8, 2015 | 05:14 PM
Zarathustra's Avatar
Car: 1987 Firebird Formula
Re: power steering
I also have the incorrect brackets for my 305 TPI. Would anyone be so kind as to post a photo of their installed power steering pump? The service manual seems to indicate that a second bracket is required on the backside of the pump.
Old Apr 8, 2015 | 07:22 PM
GageBrand's Avatar
Car: 1985 Iroc-z28
Engine: 5.7l TPI
Axle/Gears: Stock
Re: power steering
Agreed!
Old Apr 8, 2015 | 07:51 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Re: power steering
See attached for v-belt setup.
Take note of the RPO codes for A/C and without A/C.
C40/C41 = without A/C
C60/C67 = with A/C
Old Apr 8, 2015 | 10:49 PM
GageBrand's Avatar
Car: 1985 Iroc-z28
Engine: 5.7l TPI
Axle/Gears: Stock
Re: power steering
Thank you, something to go off of rather than being blind trying to fix it, since they don't sell that part anywhere im going to have to hunt for one in a junkyard or something.
Old Apr 9, 2015 | 11:01 AM
Re: power steering
That 3rd .pdf is identical to the one in my firebird service manual. The front bracket is readily available online, $20 to $30 before shipping. I've not been able to find a rear bracket anywhere. I suppose I can fabricate one, but my engine has an A/C retrofit kit from Classic Auto Air which uses an adapter bracket. This may interfere with the power steering mounting brackets. When I take the plunge and try to figure it out, I will post photos and explanations of what worked and what didn't.
Old Apr 21, 2015 | 04:11 PM
Re: power steering
Just got my new power steering front bracket from Classic Industries. I'll have to wing it on the rear bracket, but photos should be coming soon!
Old Apr 23, 2015 | 11:28 AM
Re: power steering
As soon as I figure out posting pics, I'll put them up.
Old Apr 23, 2015 | 12:10 PM
Re: power steering
PSB.jpg: My new bracket from Classic industries
PSB1.jpg: Previous owner's cheesy bracket. Note A/C retrofit bracket from Classic Auto Air
PSB2.jpg: Removed A/C compressor. 3 bolt holes for A/C bracket
PSB3.jpg: Unmounted Power Steering pump
PSB4.jpg: Previous owner's cheesy brackets
PSB5.jpg: Pump with pulley removed.
Attached Thumbnails power steering-psb.jpg   power steering-psb1.jpg   power steering-psb2.jpg   power steering-psb3.jpg   power steering-psb4.jpg
Old Apr 23, 2015 | 12:12 PM
Re: power steering
PSB6.jpg: Remounting the pump. Currently attached at two points of contact shown. Need to invent something for the third point of contact off to the right side of the bracket.
PSB7.jpg: All finished. Bracket outlined in yellow.
Any questions/comments?
Old Apr 24, 2015 | 07:05 PM
estesformula87's Avatar
Car: 90 camaro rs
Engine: 409 sbc
Transmission: th350
Re: power steering
just so some know the factory brackets can be bought from your local auto parts store still if they tell you they cant get them they are just lazy and didnt look very hard as alot of parts stores do alot you would be amazed at what oreillys or autozone can really get if they take the time to look most just enter you car in the computer and go well it dont show it must be a dealer item then you should reply have you looked in your books or called your corporate office parts specialist
i promise this i ordered one from orielly just six months ago after they told me three times they couldnt get one just took the right not lazy person to look it up
Squeaky8791
Feb 5, 2020 08:29 PM
Vintageracer
Jan 10, 2020 05:33 PM
Chuck84TA
Jul 15, 2016 09:05 PM
evilstuie
Apr 14, 2016 08:52 PM
deracer
Apr 11, 2016 12:04 AM
