oilpan gasget
Old Apr 6, 2015 | 08:56 AM
devilfish's Avatar
oilpan gasget
I got myself a new 1pc rubber oilpan gasget.
Should I install it dry or use RTV somewhere?
Any tips?
Old Apr 6, 2015 | 09:00 AM
apie2546's Avatar
Car: 86 Trans Am
Engine: 305 LB9
Re: oilpan gasget
If you got a thick one piece "gasket", install it but with only dabs if rtv on the corners to prevent leaking and a tiny amount on the block.
Old Apr 6, 2015 | 10:12 AM
devilfish's Avatar
Re: oilpan gasget
On the corners on the block aswell?
Old Apr 6, 2015 | 11:19 AM
Restrorob's Avatar
Car: 88 GTA
Engine: Built 355 to install
Transmission: Built turbo 350
Re: oilpan gasget
I just installed my one piece gasket yesterday, I put a dab of gasket eliminator in the corners on the block then installed the gasket, then a small dab on the gasket in the corners then sat the pan on.....
Old Apr 6, 2015 | 02:20 PM
Es_91rs's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Re: oilpan gasget
I've used the felpro one piece gaskets on two cars and so far I've had really good luck with installing them without any rtv.
Old Apr 6, 2015 | 04:22 PM
devilfish's Avatar
Re: oilpan gasget
Thanks!
2 dope
May 13, 2005 07:26 PM
SST12
Apr 30, 2004 10:23 AM
benroc
Jan 18, 2004 04:31 PM
SkyWarrior
Carburetors
Jul 12, 2003 01:24 PM
bobR
Carburetors
Feb 16, 2003 10:13 PM
