Hydraulic Lifter Assembly Question
Old Apr 13, 2015 | 12:53 PM
Hello, Michael's Avatar
Car: 1987 Pontiac Firebird Trans Am WS6
Engine: SBC 350
Axle/Gears: 3.70:1 BW M78 9-Bolt Posi
I took apart one of my hydraulic roller lifters. When I went to reassemble it, I noticed that the lifter body has holes on the outside on the fore and aft side of the lifter. The small piston that goes inside also has small holes in it. Do the holes on the lifter body and on the piston need to be aligned when reassembled? The piston is completely round, which tells me that it is free to rotate inside the lifter body if it needs to. So, that tells me that even if the holes were installed lined up, they could go out of alignment when the engine runs. Thanks.
Old Apr 15, 2015 | 02:05 PM
Piston454's Avatar
Car: 1990 RS Camaro
Engine: 400 sbc throttle body
Transmission: world class t5 manual
Axle/Gears: 3.73's, Detroit TrueTrac
Re: Hydraulic Lifter Assembly Question
They don't need to be aligned up. Make sure you get that small spring that's in the bottom of the lifter assembly strait up and down. I took mine apart and one of those springs was laying in there sideways and the lifter wouldn't pump up and it caused my rocker to slap the top of the valve stem because I couldn't get it adjusted. Ended up taking the top end of the motor apart. Just trying to save you some headache.
Cleotiz
Jan 6, 2018 08:56 PM
Mickeyruder
Sep 2, 2015 02:45 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
redmaroz
Aug 16, 2015 11:40 PM
