Need assistance with Codes 43 - 45- 53
Car: 84,85,86 TA, 88 GTA, 89 Fo, 92 Fo
Stock 91 305 TPI 5 speed
Codes, 43, 45, & 53
Car is intermittently running great for a while, then out of know where run extremely rough and rich throwing these codes...next time I start to drive it its fine a few times, then a its bad...
Odd that it is intermittent.
Thoughts on where to start?
Codes, 43, 45, & 53
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Need assistance with Codes 43 - 45- 53
I would start with code 43 , see link in post #2.
This could be a bad ECM.
https://www.thirdgen.org/forums/tpi/...i-missing.html
I will read through that. As I was researching code 43 I found someone stating that the knock sensor wire running against the spark plug wires could cause this..... I went & checked it & it was resting against 2 wires. I went to pull the end off the sensor to re route it & the whole plug fell apart.... So, could that be the problem? Also where would I find this connector to splice in?
Thank you
Thank you
Engine: Lb9
Transmission: M20
http://www.ebay.com/itm/ACDelco-PT308-Knock-Sensor-Connector-/171776763241?hash=item27feb16569&vxp=mtrThat would do it, then disconnect the battery for 10 min or so and see if the code 45 comes back.
http://www.chevythunder.com/o2_sensor_code_45.htm
Does the color of the wire matter? found another listening for that motor, says correct blue wire, it is tan on the car.
Engine: Lb9
Transmission: M20
Your correct the wire color is blue, you maybe able to find the pigtail with a white wire but it doesn't matter as long as it's soldered shrink tubed and reinstalled. Or a crimp shrink weather proof connecter.
Ordered the connecter
Just went & started the car, with no knock sensor connected and the car ran fine, however, just ran very rich. Plus no SES light.
Engine: Lb9
Transmission: M20
Do you have a greyish colored body injector ?
Normally you will have a code set when driving without knock sensor. Mine wasn't connected when I got the car and it was setting code 43, I guess, all the time. But it only showed up when driving about more than 20 minutes or so.
Engine: Lb9
Transmission: M20
Those are super problematic, due to age I would put a new pressure regulator in and a set of bosh3s 19#hr from Southbay fuel injectors.
