Tranny temp gauge in trans am
Car: 86 Trans Am
Engine: 305 LB9
I was looking at some old threads on here and before I leave for school again I wanted to add a trans temp gauge.
My plan is to mount it on the right side kick panel on the drivers side next to the radio area. So its out of the way until I need it basically. Just an autometer.
I was looking, is the tranny pan the best place to install it? And any tips on doing that?
Any install pics would be great on a firebird. A lot of the old threads have broken pics
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Re: Tranny temp gauge in trans am
As far as where to mount the gauge in the car, I'd personally buy a pillar gauge pod and mount it there, up and out of the way.
Car: '91 GTA
Engine: 421sbc
Transmission: Powerglide
Axle/Gears: Ford 9" with 3.89
I put mine a little too close to the header, but have not hooked it up yet.
Better spot would be on the back side of the pan.
Car: 86 Trans Am
Engine: 305 LB9
Sounds good then, I'll set this up when I go to change my tranny fluid next.
Doing small things that will still benefit my car when I slap a 350 in it
ambainb
Apr 25, 2016 09:21 PM
Zachattack0925
Aug 12, 2015 09:52 PM
